crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0RadioShack 22-510 Switching Power Supplycrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. RadioShack 22-510 Switching Power Supply Teardown, Disconnect Supply Power: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Disconnect Supply Power: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure the power supply is unplugged from mains power before continuing. If the device is powered on during disassembly, serious harm or death may occur.
    • The entire power supply can be taken apart with a Phillips screwdriver and adjustable wrench.
  2. RadioShack 22-510 Switching Power Supply Teardown, Remove the Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove the Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove the Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Removing the eight cover screws on either side of the power supply allows the cover to lift off
    • Screws can be organized using an iFixit Magnetic Project Mat
    • A fuse protects the system from overcurrent conditions and the chassis is grounded to protect the user from shorts to the case.
  3. RadioShack 22-510 Switching Power Supply Teardown, Remove Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove Fan: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The fan connector pulls out by hand. The spade terminal connectors may require coaxing with a pair of pliers.
    • The Sunon MagLev KDE1205PFV2 runs at 4300 RPM for a maximum airflow of 13 CFM. A dirty fan might not meet these specifications. Remember to clean your fans!
  4. RadioShack 22-510 Switching Power Supply Teardown, Remove Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove Switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove Switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The illuminated switch is connected by two sets of black and white AC wires and held in by two locking tabs.
    • The switch is hooked up to the primary side of the circuit. If the switch faults while energized, it has potential to shock the user.
  5. RadioShack 22-510 Switching Power Supply Teardown, Remove Heatsink and Heat Spreader: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove Heatsink and Heat Spreader: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the heatsink from the spreader reveals the liberal use of thermal paste. Try not to get it on your hands, it's tough to wash off!
    • The silver heat spreader is screwed to the chassis and must be detached before removing the board.
  6. RadioShack 22-510 Switching Power Supply Teardown, Remove the Board From the Chassis: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove the Board From the Chassis: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RadioShack 22-510 Switching Power Supply Teardown, Remove the Board From the Chassis: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The board lifts out of the chassis after removing the five screws holding it down.
    • The capacitors may still be charged, do not touch the terminals! The capacitors can be discharged by shorting the terminals with an insulated screwdriver.
    • The UC3842BN PWM controller handles the switching feedback.
    • The chassis has a sheet of plastic for short circuit prevention under the board.
    • A thermally conductive pad lies under the heatsink assembly for additional cooling capability.
    • Organized parts make reassembly a breeze.
mooflips
crwdns2935283:008/17/13crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 3,141
