Pwnagotchi Teardown
  1. Pwnagotchi Teardown, Pwnagotchi Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing the casing from the Pwnagotchi, there are two LED's with different functions
    • The green LED is the Rasperry Pi Zero's data indicator. This will flash as the SD card is being read/written to
    • You have the option to disable the LED if you connect to your Pwnagotchi and change it in the settings
    • The Blue LED is from the embedded battery in the Pwnagtochi casing. This LED only turns on when the battery is being used
  2. Pwnagotchi Teardown, Removing the Outer Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step is Optional if you have a Pwnagotchi without a case.
    • If possible, remove the outer casing of your Pwnagotchi. For this guide, our case has a removeable top and bottom so we can access the screen and battery
  3. Pwnagotchi Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pwnagotchi Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Top cover removed, we can see that the Pwnagotchi has a Waveshare E-Ink Display.
    • This area is covered by the 3D printed case to protect the display ribbon and electronics
    • The GIPO Ports all go inside the raspberry Pi Zero, you will not need the white, 8-pin header (It can be removed if you want to have a slimmer pwnagotchi)
    • This Pwnagotchi utilizes the V2 Display because of the better refresh rate. There is less ghosting on the display compares to the V1
  4. Pwnagotchi Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removing the bottom case, there is a 3.7 Volt Lithium-Ion Battery powering the device with 1200mAh
    • When building the Pwnagotchi, you can use a battery (shown in the picture) or an external power source, such as an external battery pack
  5. Pwnagotchi Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Upon removing the E-Ink Display, there is a Raspberry Pi Zero WH that runs the Operating System for the Pwnagotchi
    • The SD card runs the OS behind the Scenes, and for this case, is protected from accidently slipping out or being removed
  6. Pwnagotchi Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To access the battery, we will be removing (4) of the M3 screws holding the Pi down with a Phillips head screwdriver
  7. Pwnagotchi Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are removed, separate the Pi and the PiSugar Battery
    • These Pins connect to the Pi and provide power for the Device
  8. Pwnagotchi Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is connected to the board via magnet and can be separated from the board to get a better look at the workings
    • Be careful when separating the magnets as there are two power wires connecting the wire and the board
  9. Pwnagotchi Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are different connectors for this build, to better understand them, this is what they are used for:
    • Connectors/Ports on the raspberry pi zero
    • Mini HDMI Port
    • USB OTG (On-The-Go) Port
    • Power Port (Rated around 5-5.25V)
    • Ports/Connectors on the battery
    • Battery Power port
    • Battery Power Switch
  10. Pwnagotchi Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the Pwnagotchi completely taken apart
Pookie
crwdns2935283:001/11/18crwdne2935283:0
2,990 crwdns2915208:0crwdne2915208:0
Japanese Translators crwdns2935289:0Japanese Translatorscrwdne2935289:0
Community
crwdns2931471:06crwdne2931471:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 2,261
