crwdns2936621:0crwdne2936621:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Powerbeats Procrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    crwdns2935195:0crwdne2935195:0
    • The battery is a fairly common button-cell, and is only lightly soldered in place, meaning battery swaps are technically possible with the right tools.
    • The earbuds’ opening procedure is not totally destructive per se, but it will likely lead to at least some cosmetic damage.
    • The earbuds’ internal circuitry is all connected with fragile ribbon cables that do not detach, so a full disassembly can only be accomplished destructively.
    • The charging case is a nightmarish bucket of glue, making potential battery replacements unnecessarily difficult and destructive.
    crwdns2935097:0crwdne2935097:0
    crwdns2935197:01crwdne2935197:0
    crwdns2935199:0crwdne2935199:0
Taylor Dixon
crwdns2935283:006/26/18crwdne2935283:0
69.979 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Review missed the debris screens in the ear tubes which often get damaged. How to replace possibly.
chronus - crwdns2934203:0crwdne2934203:0
I can’t connect them when they are in the case are connect if I take them out of the case they disconnected. and it says they need to be on and on range help please
Eduardo Gaspar - crwdns2934203:0crwdne2934203:0
So far it is just the case for mine that seems broken - It won’t charge the buds properly. I really don’t mind cosmetic damage if I can replace the case’s battery (assuming that is the culprit). Where might I get a replacement battery? Also, if I used enough care, could I not just cut into the case closer to the battery to get at it from underneath?
Tom Hernandez - crwdns2934203:0crwdne2934203:0
I pushed my mesh in on one of my pods. Is there any fix to just bring it back?
AuxCord Broke - crwdns2934203:0crwdne2934203:0
My volume button is stuck. It will turn up and change songs. However I can not turn down the volume at all. Can I fix it somehow?
Lisa Nikodym - crwdns2934203:0crwdne2934203:0
Is there a way to replace the part that wraps around the ear the soft rubbery bit got chewed off by a hungry puppy. I was hoping to see that you can in the teardown but it just handled the tech. Thanks guys love what you do!
Psyguy - crwdns2934203:0crwdne2934203:0
my Right powerbeats pro disconnect when battery rich 50% do I have to replace the battery I reset it many times but no impruvment.
John Light - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 84
crwdns2936753:030crwdne2936753:0 371
crwdns2942667:0crwdne2942667:0 46,296
