crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Power Mac G4 M5183crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Power Mac G4 M5183 Teardown STEM Project, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the tab to open the case.
  2. Power Mac G4 M5183 Teardown STEM Project, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the white tabs down
    • Lift up the RAM
    • Repeat x4
  3. Power Mac G4 M5183 Teardown STEM Project, Heat-sink: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Heat-sink: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flat head screwdriver or spudger to lift up the tabs that hold down the heat-sink.
    • Repeat x2
    • The heat-sink should just lift right off.
  4. Power Mac G4 M5183 Teardown STEM Project, GPU: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, GPU: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove highlighted screw.
    • The GPU should lift right out.
  5. Power Mac G4 M5183 Teardown STEM Project, Mother Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Mother Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Mother Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove highlighted cables.
    • Remove highlighted screws.
    • Lift out the motherboard. (Note: pull to the left to clear the ports from the case)
  6. Power Mac G4 M5183 Teardown STEM Project, CPU: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, CPU: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the screws, simply lift off the CPU from the connector. Use only a minimal amount of pressure when pulling the CPU from the connector.
    • This is the connector after removal of the CPU.
  7. Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the face plate. You are supposed to press down the highlighted tabs from the inside.
    • Slide out the drive. (MAKE SURE TO UNHOOK THE CABLES)
  8. Power Mac G4 M5183 Teardown STEM Project, Hard drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Hard drive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Hard drive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the highlighted cables.
    • Lift out the hard drive.
  9. Power Mac G4 M5183 Teardown STEM Project, Main Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Main Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove highlighted screw. ( SAME SCREW ON OPPOSITE SIDE, REMOVE THAT AS WELL.)
    • Disconnect the connector.
    • After that, just pull it out.
  10. Power Mac G4 M5183 Teardown STEM Project, Power Supply: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Power Supply: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Power Mac G4 M5183 Teardown STEM Project, Power Supply: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 2.5 mm hex key to remove these screws.
    • Feed the wires through the highlighted hole, then pull out the power supply.
  11. Power Mac G4 M5183 Teardown STEM Project, Finished!: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will be left with an empty case.
Harrison Case
crwdns2935283:011/06/16crwdne2935283:0
128 crwdns2915208:0crwdne2915208:0
Just a little tip.
APPLE tend to use screw connections as a means of ground continuity.
That is - if the CPU card is not screwed down - it might not power on.
Mal - crwdns2934203:0crwdne2934203:0
The is a kit from thelaserhive.com to allow an mATX board to be used inside the G4 cases.
Pete Karnowski - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,740
