This guide is for my engineering class. My goal is to show you how to fully gut a Power Mac G4.
Pull the white tabs down
Lift up the RAM
Repeat x4
Use a flat head screwdriver or spudger to lift up the tabs that hold down the heat-sink.
Repeat x2
The heat-sink should just lift right off.
Remove highlighted screw.
The GPU should lift right out.
Remove highlighted cables.
Remove highlighted screws.
Lift out the motherboard. (Note: pull to the left to clear the ports from the case)
After removing the screws, simply lift off the CPU from the connector. Use only a minimal amount of pressure when pulling the CPU from the connector.
This is the connector after removal of the CPU.
Remove the face plate. You are supposed to press down the highlighted tabs from the inside.
Slide out the drive. (MAKE SURE TO UNHOOK THE CABLES)
Remove the highlighted cables.
Lift out the hard drive.
Remove highlighted screw. ( SAME SCREW ON OPPOSITE SIDE, REMOVE THAT AS WELL.)
Disconnect the connector.
After that, just pull it out.
Use a 2.5 mm hex key to remove these screws.
Feed the wires through the highlighted hole, then pull out the power supply.
You will be left with an empty case.
crwdns2944067:04crwdne2944067:0
Just a little tip.
APPLE tend to use screw connections as a means of ground continuity.
That is - if the CPU card is not screwed down - it might not power on.
The is a kit from thelaserhive.com to allow an mATX board to be used inside the G4 cases.
como retiro las tapas de los lados para hacerlelimpieza
martin alonso moncada gonzalez - crwdns2934203:0crwdne2934203:0
Sieh hier nach
