Before disassembling, unplug the Camera from the PS4.
There are two PH0 Screws in the socket which hold the cable.
Unscrew two PH0 Screws and pull off the cable holder.
The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious.
There is one more PH0 screw to remove. This one is behind the other lens.
This was the easy part.
Encore two photos where to locate these nasty clips
The other half of the housing is attached to a solid U-Frame with the electronics.
There are four silver screws, PH0.
Four microphones, two with black/yellow cables and two with black/red wiring.
The backside of the U-frame. The cable is not soldered, there is a plug.
Detail of the plug.
Whats the make of the cable.. What do I search for in order to buy a new one
6 PH1 screws. Take a small magnet to hold them.
The connector of the mikrophone-array
The lenses, plastic, glued tight.
NOT ADJUSTABLE.
Backside, two small PH0 at each CCD. But the Cameramodules are clued to the board,too - without destruction, you can not open it.
I want to save it as spare-part, so i don't want to open it. So here is finito capito. :) Thanks for watching...
Extra: The wiring.
It's an USB3 cable without green/white Pimf. There are three SEPARATE ISOLATED metalfoil shields with wire, red-black-power and two Pimf yellow/blue and orange/green. So ja, thats it. Paulaner.
crwdns2944067:07crwdne2944067:0
Only 7 steps? Where is the rest of the teardown? I wanted to see detailed images of the optics.
Ja, okay, i made some pictures for you. The optics are in Step 10.
Enjoy.
Freundliche Grüsse. :)
Does anyone think it would be possible to cut the wires from two cameras and splice the wires together and put the power on a A/B rocker switch to switch between two cameras?
Great job, congrats. Do you have also for the other version of ps4 camera same as this one? BR.
I'm wondering if it can even be spliced or soldered back together and actually work
Hi,i want to take out 2 microfons from inside a camera,and to use that microfones to solder on a ps4 wired microfone,is it possible?Thanks
What's the name of this USB cable? I need to replace mine…
