crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0PlayStation 3 Slimcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. PlayStation 3 Slim Teardown, Console Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 3 Slim Teardown, Console Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the PlayStation 3 over to have the bottom facing up. It helps to have the disk drive towards you. Remove the three removable feet on the corners hiding the screws.
    • Remove the 7 long screws and single short screw on the base of the Playstation.
    • There are 4 short black screws that are on the underside of the disk drive that need to be removed.
    • Flip the Playstation back over to remove the top of the Playstation 3.
    • On the outside of the PS3 slim we find a matte black finish and a build that is noticeably not as wide as the original Playstation 3.
  2. PlayStation 3 Slim Teardown, Inside the console: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Inside the console: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Inside the console: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug 2 wires from power supply.
    • Remove 2 screws next to the removed wires
    • Lift power supply up and out
    • Pry up power and eject button module. Careful of ribbon cable.
    • Unplug antenna wires and remove cable to disk drive. Lift grey tab on ribbon wire connector and unplug cable.
    • Remove screw holding down the disk drive. Remove wires from white tape where necessary to remove disk drive, try to keep intact for reuse.
    • Unplug power button ribbon Cable. Remove screws retaining motherboard. (Yellow has a screw present on a cech-2001a, but not on the model pictured) Lift motherboard up in the front and remove.
  3. PlayStation 3 Slim Teardown, Motherboard Shield: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 3 Slim Teardown, Motherboard Shield: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove screws holding motherboard shield together.
    • Remove screws holding the heat sink to board, and remove bottom side of motherboard screws.
  4. PlayStation 3 Slim Teardown, Mother board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Mother board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Mother board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry up front of motherboard, it will be effectively glued by the thermal paste especially if dried out. Take your time and it will come loose.
    • Clean off thermal paste on both sides with Isopropanol to prepare for repasting/reassembly.
  5. PlayStation 3 Slim Teardown, Power supply: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Power supply: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Power supply: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  6. PlayStation 3 Slim Teardown, Bluray Driver: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Bluray Driver: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 3 Slim Teardown, Bluray Driver: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
Vinicius Rodrigues Bellini
crwdns2935283:012/12/22crwdne2935283:0
1,086 crwdns2915208:0crwdne2915208:0
mi ps3 si prende pero no da imagen ni sonido
-el cable HDMI si funciona
thomas - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 145
crwdns2936753:030crwdne2936753:0 596
crwdns2942667:0crwdne2942667:0 14,506
