crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Philips HX8210-22 Sonicare Airfloss Microjetcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Open main case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Open main case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is the most difficult part: to open the main case you have to apply the correct pressure on the sides. I managed to open it by wriggling it a bit while pulling. Check the picture to see how the two parts are clipped, it should give you a better idea of how to manage to open it.
  2. Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Extract components from case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Extract components from case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Extract components from case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently unplug the main board from the mechanical parts, pulling it up from the bottom (it is not glued)
    • Remove the tape holding the cables
    • Unplug the water cable
    • You can now pull out all the components, you willl have only four cables going to the upper part (for the battery and the trigger button)
  3. Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Inspect main board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Inspect main board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inspect the main board
  4. Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Inspect mechanical parts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Inspect mechanical parts: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inspect mechanical parts
  5. Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Remove battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Remove battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HX8210/22 Sonicare Airfloss Microjet Teardown, Remove battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is glued to the upper part, you can remove it by gently pulling it from the case with a flat screwdrier
Giulio Marcon
crwdns2935283:005/11/21crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 836
