A look inside the Panasonic RZ-S50W (Japan) / RZ-S500W (Outside Japan) Bluetooth Headphones
Features:
Exceptional Sound and Noise Cancellation. Multiple MEMS microphones
Optimum Sound Isolation
Strong, Stable Connection
High-Quality Calling Sound
Approximately, 6 hours playback, and up to 20 Hours of use with charger
Bluetooth® 5.0
Capacitive touch sensor control
What is in the box
Headphones / Charging Case
USB 'C' Cable
Headphone rubber tips for different sizes of ears
User's Manual
Charging case with headphones
Close up view of headphones
Side views of Headphone
MEMS Microphones
Speaker Spatial Vent Port
Speaker Sound Port
Speaker Vent
USB Interface
Charger Interface
Vent Port
View of Headphone with rubber ear piece [cap] removed
Vent Port
Since the Panasonic Headphone enclosure is glued together, the only way in was to cut into the headphone.
This is a destructive teardown
A Razsor Knife was use to cut into the Panasonic headphone along the seam in the headphone. Then a Jimmy Tool was used to open up the headphone
Once opened, we get our first look at the inside of the headphone
Opening up the headphone, we can see the main PCB, Battery, Speaker, etc. Tweezers and a Pick Tool were used to removed the electronics from the enclosure
Double sided foam tape was used to hold the main the PCB to the Battery and to the Touch Sensor / Antenna PCB. This foam tape had to be cut free. Then Denatured Alcohol was used to remove the foam tape glue from the PCBs and Battery
Battery
Main PCB
Speaker Area
Touch Sensor and Antenna
Double Sided Foam Tape
At first, I wasn't sure about the solder balls. Then I realized they are used to anchor the USB and Power Interface pins on the outside of the Headphone to the internal circuit board.
I had to used a soldering iron to remove the solder balls, so that the internal interface circuit board could be removed. I had to also remove solder from the speaker wires to free up the internal circuit board.
The internal circuit board was also attached a MEMS Microphone that appeared to be monitoring the Speaker Chamber of the Headphone, since it was faced in. I had to remove the outside panel with 'R' on it with a Razor Knife to free the MEMS Microphone. Once the MEMS Microphone was freed, the interface circuit board could be pulled out
USB and Power (Charger) Interface
MEMS Microphone
Sound Ports
Speaker Wires
Internal Circuit Board that interface Power and USB to the Headphones
There was not much to see on the internal interface board. The was one IC component that could not be crossed. If you happen to know the component, please leave a comment below
Unknown Component
Full Sensor Flex/Charging PCB IC Identification:
Next the Speaker sound chamber cover was removed with the use of a Pick Tool and Tweezers. A Razor Knife was used to cut the glue holding the speak in place
The speaker had no identifiable markings
With Speaker removed, we can see the sound chamber and sound ports
Closeup view of the Battery
Li-Ion 3.7V, 0.32Wh
The battery appears to be from VDL Electronics Co., Shenzhen, China
Closeup view of the Antenna/Touch Sensor side of the Main PCB
DSP Group - C2A1A Hybrid Active Noise Cancellation (ANC) Codec and Audio Digital Signal Processor (DSP)
651DF1M9 - Could not cross part number, but during a web search found out that it may be an integrated battery management IC
W25Q32JWUUIMTR- SPI FLASH 32Mb
MEMS Microphone Port
Closeup view of some of the components on the Antenna/Touch Sensor side of the Main PCB
I believe the 651DF1M9 may be a integrated battery protection IC
Battery side close up view of the Main PCB
AIROHA AB1552 - ARM Cortex M4/Bluetooth 5.0 Dual Mode
927 MPS1 MEMS Microphone. The Headphone uses three MEMS microphones with this part number
Could not cross the part number. If you know the part, please leave a comment below. The 2D bar code on the part reads as STM927352NH2S011
Crystal Oscillator
Unknown component. Labelled B2A. Please leave a comment if you happen to know this component
Unknown component. Labelled SV4CP 240. Please leave a comment if you happen to know this component. Separated from PCB during teardown
Closeup view of some of the components on the Battery side of the Main PCB
927 MPS1 MEMS Microphone. The Headphone uses three of these MEMS microphones
Unknown component. Labelled B2A. Please leave a comment if you happen to know this componentNew line.
Closeup view of top and bottom side of the Touch Sensor Flex PCB and PCB Antenna
Predicted Block Diagram of the Panasonic RZ-S50W Bluetooth Headphones:
Teardown Exploded View of the Panasonic Headphone
If you can, can you post the teardown of the charging case too?
Dong a web search, I believe the glue removed from the speaker was a silicone dome used to help compress sound waves?
yes second the charging case!
