crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Panasonic EB TX320ASWcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
  2. Panasonic EB TX320ASW Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove battery push clip in; battery will pop out.
  3. Panasonic EB TX320ASW Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Star 3.0 bit, remove 4 screws in battery compartment.
  4. Panasonic EB TX320ASW Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
  5. Panasonic EB TX320ASW Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
    • If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
  6. Panasonic EB TX320ASW Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
  7. Panasonic EB TX320ASW Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove speaker cover, pull out silver plate.
  8. Panasonic EB TX320ASW Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
    • If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
  9. Panasonic EB TX320ASW Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
  10. Panasonic EB TX320ASW Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
  11. Panasonic EB TX320ASW Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic EB TX320ASW Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
    • If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
Andrew Foss
crwdns2935283:010/04/11crwdne2935283:0
10 crwdns2915208:0crwdne2915208:0
UW Stout, Team 5-2, Zhou Fall 2011 crwdns2935289:0UW Stout, Team 5-2, Zhou Fall 2011crwdne2935289:0
UWSTOUT-ZHOU-F11S5G2
crwdns2942667:0crwdne2942667:0 3,591
