crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0PSP E1000crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. PSP E1000 Teardown, PSP E1000 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown, PSP E1000 Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is the front and back of the PSP E1000
  2. PSP E1000 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We are going to start by removing the back panel.
    • To do this open the panel and gently squeeze in the UMD tray until it pops up.
    • It should lay flat against the back panel while open if done correctly
  3. PSP E1000 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently bend the back panel to free the hinge on the left.
    • Once it is popped out it should look like the second photo
    • The back panel can then be slid off
  4. PSP E1000 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw with a #00 Philips and slide up the battery cover.
    • The battery can now be removed by pulling it out.
    • When reinstalling it is useful to use a spudger to push the cable back in.
  5. PSP E1000 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all four screws on the back using the same bit as before.
    • Then remove the two top screws.
    • Then, insert a spudger between the L button and the face plate and separate them. Then, do the same on the right.
    • Then slide the face plate down towards the bottom of the screen to release the bottom clips.
    • Ensure you support the face plate as the front buttons are still connected with a fragile ribbon cable.
  6. PSP E1000 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a spudger under both of these clips to release the display
    • Then gently rotate the display to the left side of the device so you can see the mainboard.
  7. PSP E1000 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently unclip the display ribbon cable and remove it
    • Then set the display to the side
    • Untape the front panel ribbon cable, unclip it, then remove it.
  8. PSP E1000 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ribbon cable and power cable
    • Gently lift the button assembly and charge port
    • The shoulder button is taped down so slide a spudger under the button and gently peel it off
  9. PSP E1000 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip and remove the two marked ribbon cables
    • Remove the marked screw and lift the analog stick out
    • Lift the button pad carefully and peel off the shoulder button
    • When reassembling install the joystick before the buttons.
  10. PSP E1000 Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip both ribbon cables and remove them
    • Remove the marked screw on the mainboard
    • Lift the bottom of the mainboard up and slide it out
    • For reinstallation make sure that the power switch cover is installed before it is screwed in. It has to be unscrewed to do the installation
  11. PSP E1000 Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device and remove the marked screws
    • Without touching the lens lift the UMD reader from the device
  12. PSP E1000 Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP E1000 Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Congratulations you have disassembled your PSP E1000. Have fun with the reassembly!
Caleb Pierce
crwdns2935283:004/19/22crwdne2935283:0
1,061 crwdns2915208:0crwdne2915208:0
My aim was to clean the inside, so I only disassembled it up to the screen, but I accidentally pulled the socket where the volume button is connected hard.So that black thing broke but the part that goes into the socket is intact. Finally, after cleaning it, I plugged it into the socket, then I put the LCD screen into its socket and placed it. Finally, after putting the device back into its parts, I pressed the power button but the screen did not come on.
Berkay Ghoul - crwdns2934203:0crwdne2934203:0
What black thing are you referring to?
When you turned it on did the top LEDs come on or did they stay off?
Caleb Pierce - crwdns2934203:0crwdne2934203:0
Same thing for me. Got to the LCD part to clean the dust, plugged everything back but the green Led didn't show up when i tried to turn it on. The charging light does come on though.
Antimo Ronga - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 242
crwdns2942667:0crwdne2942667:0 1,088
