This is just a basic how-to-open guide for the Oscal Tiger 12 smartphone, and not a complete disassembly.
I also made a mistake during opening which broke the fingerprint sensor. You should avoid doing so, and I will outline this mistake in the step it is present in.
Begin by heating the back panel (where the cameras are).
Once you're done heating the back cover, it's time to remove it.
I start with a bit of a box cutter blade bit that I've wrapped in insulating tape. If you decide to do the same, do be careful when pushing it deeper in. It is very easy to leave scratch marks on the inside of the back cover.
After I get a bit of a start, I slip Jimmy in and force a bit larger gap.
After the gap is large enough, I use a plastic card to open the rest.
Not going to lie, I never catch her on the top.
Now, remove the camera cover. If you have a heat gun, heat it prior.
Remove the marked screws.
Slip something in between the LCD's frame and the external frame. Jimmy should work, but it's easier to get a start using something sharp.
Remove the fingerprint sensor.
Remove the cameras from the motherboard, then lift the black cover over the motherboard to expose the battery and LCD connectors.
Disconnect them, then remove the 2 screws that hold in the motherboard.
Now, remove the motherboard.
I recommend using a plastic spudger where marked in picture 1 to get some leverage. It's usually stuck quite a bit by some thermal paste that almost glues it to the frame.
Hi! Is it 12gb RAM version of oscal tiger12?
