crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Nokia N900crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Nokia N900 Teardown, Nokia N900 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the phone face down so the back of the phone is facing up.
  2. Nokia N900 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the slit on the side of the phone and use your fingers to gently pry off the back cover.
  3. Nokia N900 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the rectangular-shaped battery from the center of the phone.
  4. Nokia N900 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws from the top and bottom of the back of the phone.
  5. Nokia N900 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia N900 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the phone screen away from the base of the phone.
    • You should have two pieces: the phone screen and the base of the phone.
    Be aware when doing this step as the LCD flat-flex cable is still connected to the mainboard, disconnect the cable first before pulling it apart!
    Leonard Putra - crwdns2934203:0crwdne2934203:0
  6. Nokia N900 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia N900 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the keyboard mat from the base of the phone.
  7. Nokia N900 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N900 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N900 Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the blue iFixit Opening Tool under the green motherboard and the base. Gently separate the green motherboard from the base of the phone.
  8. Nokia N900 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia N900 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the base of the phone over and remove all six screws from the top and bottom of the phone.
  9. Nokia N900 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the screen and the base apart so that there's two separate pieces.
  10. Nokia N900 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia N900 Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue iFixit Opening Tool to carefully pry off the outer rim of the phone screen.
    • To avoid breakage, pry each side of the screen off individually. This will help loosen the parts and ease the disassembly process.
  11. Nokia N900 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screen is separated from the outer rim, remove the screen cover.
    • This is the final step. You should have three pieces of the disassembled screen: the outer rim, the screen, and screen cover.
    • Congrats, you've successfully completed a Nokia N900 teardown!
Juan Haro
crwdns2935283:003/13/14crwdne2935283:0
284 crwdns2915208:0crwdne2915208:0
New Mexico State, Team 1-4, Easley Spring 2014 crwdns2935289:0New Mexico State, Team 1-4, Easley Spring 2014crwdne2935289:0
NMSU-EASLEY-S14S1G4
Looks like the LCD flex cable ripped off on this teardown, ouch!
crwdns2942667:0crwdne2942667:0 5,906
