            Red arrows indicate which screws must be removed in order to get to the motherboard.
            Take T5 torx and remove all 3 screws.
            Wedge a flat head in between the back and phone exterior starting at the bottom corners.
            As you move toward the top, remove the camera and volume buttons.
            Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
