crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Nexus 4 Wireless Chargercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Nexus 4 Wireless Charger Teardown, Remove the round rubber face from the charging orb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the round rubber face from the charging orb
    • Behind the rubber face is a thin sheet of plastic, you'll need to pierce it to access the 4 screws holding the device together.
  2. Nexus 4 Wireless Charger Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screws are located at 12 o'clock, 3 o'clock, 6 o'clock and 9 o'clock, just inside the outer ring.
    • You will need to unscrew these if possible, on my unit they were glued in and I was unable to unscrew them. Instead I used a drill with a 1/8" bit to drill them out.
    • If you drill them out be careful as they are surrounded by a PCB, though I drilled into the board a bit and it still functions. Once you remove the screws use the spudger to pry the shiny black plastic face off the base.
    • You will see the seam where the shiny and matte plastic meet on the unit. There are 4 plastic clips holding it down, once they are unclipped you can remove the shiny black faceplate exposing the charging coil and main PCB.
  3. Nexus 4 Wireless Charger Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next gently pull up on the main PCB and swing it to the right. There are wires connecting the main board to the micro usb port beneath, so be gentle.
    • You will see a single screw holding down the board with the micro usb connector, unscrew it and you're done.
David Spalding
crwdns2935283:011/12/15crwdne2935283:0
6.569 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 2,951
