crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Nacon Asymmetric Wireless PS4 Controllercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Nacon Asymmetric Wireless PS4 Controller Teardown, Remove the shell screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 7 screws in total, and all require a J00 screw bit.
    • The bottom two screws are set somewhat deep and may require a longer screwdriver.
  2. Nacon Asymmetric Wireless PS4 Controller Teardown, Detach the shell cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nacon Asymmetric Wireless PS4 Controller Teardown, Detach the shell cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When the screws are removed, the shell should come off by itself. If not, gently apply some pressure.
    • In my case, the shell simply dropped off as soon as I removed the last screw.
    • The left and right sticks can be easily removed by lifting them up. They just need a bit of pressure, which then gives access to the potentiometers.
    • Note: The broken part in the bottom right grip/handle should not be present on your controller.
  3. Nacon Asymmetric Wireless PS4 Controller Teardown, Remove screws holding board to shell: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 2 screws securing the board to the top shell cover. Again, you’ll need the J00 screw bit for these.
    • Be careful when lifting, as there are ribbon cables and rumble electric motors attached.
  4. Nacon Asymmetric Wireless PS4 Controller Teardown, Remove the bumper ribbons: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nacon Asymmetric Wireless PS4 Controller Teardown, Remove the bumper ribbons: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nacon Asymmetric Wireless PS4 Controller Teardown, Remove the bumper ribbons: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before lifting the board off the top of the shell, remove the ribbon cables. They are tucked into plastic clips and plugged into the main board.
    • Lift and move the battery to access and disconnect the left and right bumper button ribbon cables from the main board.
    • Be careful, as these cables can easily break.
  5. Nacon Asymmetric Wireless PS4 Controller Teardown, Remove the second ribbon cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the last ribbon cable, pull the black plastic tab outward (towards you) to release the ribbon cable.
  6. Nacon Asymmetric Wireless PS4 Controller Teardown, Unscrew the board holding the buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nacon Asymmetric Wireless PS4 Controller Teardown, Unscrew the board holding the buttons: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nacon Asymmetric Wireless PS4 Controller Teardown, Unscrew the board holding the buttons: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 4 screws on the board that need to be removed to access the buttons. There are also 2 screws securing the touchpad in the controller. Again, you can use the J00 screw bit.
    • To remove the smaller bumper boards, simply pull them off.
  7. Nacon Asymmetric Wireless PS4 Controller Teardown, The screws and buttons: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nacon Asymmetric Wireless PS4 Controller Teardown, The screws and buttons: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • These are all the buttons and button membranes.
    • The parts inside the pink square are the light and its housing.
    • And the screws that belong to the device.
Qhixe
crwdns2935283:011/22/24crwdne2935283:0
160 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 344
crwdns2942667:0crwdne2942667:0 939
