crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Motorola i450 Boost Mobilecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Motorola i450 Boost Mobile Teardown, Antenna: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Antenna: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Antenna: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. Motorola i450 Boost Mobile Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
  3. Motorola i450 Boost Mobile Teardown, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Back Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  4. Motorola i450 Boost Mobile Teardown, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  5. Motorola i450 Boost Mobile Teardown, SIM Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola i450 Boost Mobile Teardown, SIM Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  6. Motorola i450 Boost Mobile Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  7. Motorola i450 Boost Mobile Teardown, Circuit Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Extend the antenna.
  8. Motorola i450 Boost Mobile Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  9. Motorola i450 Boost Mobile Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  10. Motorola i450 Boost Mobile Teardown, Keypad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Keypad: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Teardown, Keypad: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the end of the circuit board farthest from the phone hinge.
    • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
    • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
  11. Motorola i450 Boost Mobile Teardown, Motorola i450 Boost Mobile Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Exploded view of all phone components.
Nathan Heavner
crwdns2935283:010/22/12crwdne2935283:0
3 crwdns2915208:0crwdne2915208:0
Clemson, Team 15-2, Benson Fall 2012 crwdns2935289:0Clemson, Team 15-2, Benson Fall 2012crwdne2935289:0
CLEM-BENSON-F12S15G2
crwdns2942667:0crwdne2942667:0 1,373
