crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Motorola Moto X Forcecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Motorola Moto X Force Teardown, Remove SIM card tray.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove SIM card tray.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove it or it will be a barrier to remove motherboard.
  2. Motorola Moto X Force Teardown, Remove back cover.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove back cover.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove back cover.: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use heat gun to heat up back cover firstly.
    • Insert metal opening tool to open a gap and cut adhesives around.
    • Take care when sliding tool under the back cover, there are delicate antenna and other components that could be damaged by your glue slicing tool
  3. Motorola Moto X Force Teardown, Remove metal logo cover.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove metal logo cover.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to cut adhesives underneath.
  4. Motorola Moto X Force Teardown, Remove middle frame.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove middle frame.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove middle frame.: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist off 17 screws by T3 Torx screwdriver.
    • Take away rubber bracket securing NFC antenna and release NFC antenna connector.
  5. Motorola Moto X Force Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take away rubber bracket securing MIC flex and release microphone flex cable connector.
  6. Motorola Moto X Force Teardown, Remove side button.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
  7. Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release MIC connector.
    • There are adhesives existed underneath.
  8. Motorola Moto X Force Teardown, Remove headphone jack.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove headphone jack.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pry this part up.
  9. Motorola Moto X Force Teardown, Remove vibration motor.: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove vibration motor.: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The vibrator is only fastened by the plastic bracket.
  10. Motorola Moto X Force Teardown, Remove NFC antenna along with  plastic board attached.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove NFC antenna along with  plastic board attached.: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are a little bit adhesives around, but you can peel this part easily.
  11. Motorola Moto X Force Teardown, Remove loudspeaker.: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove loudspeaker.: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry this part up.
  12. Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the tape.
    • Twist off 2 screws.
    • Take care not to apply any lateral force to the motherboard to metal bracket electrical connector when removing the motherboard bracket. If abused, the tiny spring could break off at a later date and causing short circuits within the phone. The connector is to the right of the side button connector and above the copper film screened component.
    The motherboard bracket is electrically connected to the motherboard by a very delicate spring connector. Any lateral force on the connector will snap it off the motherboard. Take care not to apply any lateral force to the connector when removing the motherboard bracket. Any damage to the connector could result in it breaking off at a later date and causing short circuits in other components within the phone. The connector is to the right of the side button connector and above the copper film covered component.
    OuterSpaceHoppa - crwdns2934203:0crwdne2934203:0
  13. Motorola Moto X Force Teardown, Release battery connector and side button connector.: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release this two connectors carefully.
  14. Motorola Moto X Force Teardown, Release touch digitizer connector.: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Release touch digitizer connector.: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The LCD assembly has two connectors, here is touchscreen connector.
  15. Motorola Moto X Force Teardown, ReleaseLCD display connector.: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, ReleaseLCD display connector.: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This one is display connector.
  16. Motorola Moto X Force Teardown, Release motherboard assembly.: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Release motherboard assembly.: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Release motherboard assembly.: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release signal cable connector.
    • Pry the motherboard assembly up.
  17. Motorola Moto X Force Teardown, Remove rear camera.: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove rear camera.: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Moto X Force packs a 21-megapixel primary camera on the rear.
  18. Motorola Moto X Force Teardown, Release signal cable connector and remove it.: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Release signal cable connector and remove it.: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to release the connector.
  19. Motorola Moto X Force Teardown, Remove proximity sensor flex.: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove proximity sensor flex.: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
  20. Motorola Moto X Force Teardown, Pry up and remove battery.: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Pry up and remove battery.: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Non-removable Li-Ion 3760 mAh battery.
  21. Motorola Moto X Force Teardown, Remove front-facing camera.: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove front-facing camera.: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A 5-megapixel front shooter for selfies.
  22. Motorola Moto X Force Teardown, Remove earpiece.: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown, Remove earpiece.: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful to pry this part up, because it tends to fall apart easily.
  23. Motorola Moto X Force Teardown, Remove side button flex.: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove side button flex.: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto X Force Teardown, Remove side button flex.: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  24. Motorola Moto X Force Teardown: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto X Force Teardown: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them.
  25. Motorola Moto X Force Teardown: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Done.
Witrigs
crwdns2935283:011/24/15crwdne2935283:0
70.421 crwdns2915208:0crwdne2915208:0
crwdns2935297:0377crwdne2935297:0
crwdns2947412:09crwdne2947412:0
amoled
Danila Elchin - crwdns2934203:0crwdne2934203:0
Good afternoon,
Tell me what you can say on the problem faced by many users of the device.
When you connect the original or third-party charger with fast charging Functions or without fast charging function, and sometimes when using cordless phone charging on the charge indication is presented but charging rate is 1-3% per hour. This problem occurs on the Droid Turbo 2 and X force.
I would like to hear your opinion on this issue.
Vikulov Aleksander - crwdns2934203:0crwdne2934203:0
Several units are plagued by a vertical green line that appears on LCD (just search for Moto X Force or Droid Turbo 2 Green Line). Bad flex or bad LCD ?
NCQ - crwdns2934203:0crwdne2934203:0
There should be problem of lcd screen flex.
Witrigs -
I have a UK Moto X Force. I have noticed that the green line appears when You push harder between the screen and right loudspeaker hole. it disapears when I remove my finger. I hope this green line wont become permanent :/
Dxt D -
Does this tutorial works with Moto X Play?
werther - crwdns2934203:0crwdne2934203:0
can i use droit turbo 2 logic board on moto x force? i whant to change logic board becous my is crashed
sandro bitarishvili - crwdns2934203:0crwdne2934203:0
:) Several very odd responses to this teardown, so I'll be the first to say.....
Thanks very very much Eric and other contributers, for taking the time to leave this guide. It's perfect and helped me get the thing apart without killing it - aint they a pain when they keep turning back on? I just want to mention thsi one extra bit.....
Be careful when prizing the back off the phone, it stuck so well on the one I've just done (even though I've fixed dozens of phones and am very familiar with the 'heating up' process to soften the glue, well in fidlling about with it, I was horrified to see I'd pressed the buttons in just the right way to get it to boot into its RECOVERY menu, and one more button press would have erased the customers contents!! *gulps*.
This happened despite the fact that the phones battery has been so flat it could never turn on beyond showing the Flat Battery logo - still had enough power to get into Recovery LoL.
Many thanks again Eric :-)
assortedrubbish - crwdns2934203:0crwdne2934203:0
Hi, i bouth a Motorola x force, and i have a problem with the dual sim, the sim 2 does not work as a sim, but work when i use with a memory card.- Thank you!!
Juan Diego - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 18,982
