crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Moto G4crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Motorola Moto G4 Teardown, Motorola Moto G4 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G4 Teardown, Motorola Moto G4 Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your thumb in the indent located at bottom left corner of the back cover.
    • The cover will pop up and begin to lift.
    • Continue to slide your fingers up the sides to remove the back cover.
  2. Motorola Moto G4 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the gray plastic surrounding the camera lens.
    • There will be a lot of glue and you may have to pull hard on the plastic piece.
  3. Motorola Moto G4 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers, slide under all sides of the lens to loosen it.
    • Pulls the lens towards you to remove the lens.
    • There will be glue under the lens. You may have to pull hard to remove the lens.
    • Do not pull too hard on the lens. Pulling hard on it can result in breaking the lens.
  4. Motorola Moto G4 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the screwdriver equipped with the T4 head drill bit, begin unscrewing the screws on the back panel.
    • Keep the screws on a magnetic board or strip to not lose any of them.
    • After all the screws are removed from the back panel, lift the back panel off.
  5. Motorola Moto G4 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, unhook the twisted red and black wire from under the black plastic pieces that are holding it down.
    • Using the tweezers, disconnect the wire from its connective port.
    • Use the spudger to lift the battery out.
    • The battery is glued down so you will have to use some force to pull it out.
    • Be careful not to pull it too hard it could bend the battery.
  6. Motorola Moto G4 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the tweezers, slide them under the speaker and pull the speaker out.
    • The back of the speaker is magnetic. Be careful to not touch it t other parts of the motherboard.
  7. Motorola Moto G4 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the tweezers, pull up on the clasp that is holding the motherboard down.
    • Using the tweezers, pull up on the clasp that is connecting the motherboard to the front-facing camera.
    • Using the tweezers, remove the red and black wiring from the bottom of the phone by the charging port.
  8. Motorola Moto G4 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G4 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers pull up on the three corners of the motherboard until it comes out.
Kierra Schau
crwdns2935283:009/28/17crwdne2935283:0
1,511 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G2, Passmore Fall 2017 crwdns2935289:0USF Tampa, Team S11-G2, Passmore Fall 2017crwdne2935289:0
USFT-PASSMORE-F17S11G2
crwdns2935297:013crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,224
