crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Motorola Defycrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Motorola Defy Teardown, Motorola Defy Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the phone
  2. Motorola Defy Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Defy Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the back there is a slider that locks the back cover on slide this over to unlock it.
  3. Motorola Defy Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and sim card as well as the micro sd if one.
  4. Motorola Defy Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two torx screws in each corner.
  5. Motorola Defy Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Defy Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 torx screws on both sides.
    • Now remove one more torx screw on the bottom.
  6. Motorola Defy Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pry tool and insert in between the black and white plastic. Slide across all sides to unlock the clips holding it together.
  7. Motorola Defy Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Defy Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Defy Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the the back case (white section) revealing the logic board.
  8. Motorola Defy Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Defy Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Defy Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pry tool and detach the digitizer cable and LCD cable from the board.
  9. Motorola Defy Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the logic board out of the phone revealing the LCD.
  10. Motorola Defy Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use pry tool to gently lift the LCD out of the phone revealing the digitizer.
    i would like to reuse LCD, does anyone know how connect and what to send to the display
    lub - crwdns2934203:0crwdne2934203:0
  11. Motorola Defy Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now all that is left is the digitizer frame holding the digitizer.
    • To remove a broken digitizer heat the front edges of this frame to soften the digitizer adhesive and pry away from the frame.
  12. Motorola Defy Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thats it now just follow these steps in reverse to put your phone back together.
    CAUTION: Be sure not to touch the LCD screen or the back side of the digitizer after removing the protective plastic. If you do, you will see finger prints that you cannot remove after reassembling the phone.
    Ken - crwdns2934203:0crwdne2934203:0
Jared
crwdns2935283:002/14/11crwdne2935283:0
530 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Brilliant! Many thanks. Things to watch: the volume rocker and on switch tend to fall out, so secured them to the back with a little bit of masking tape while I reassembled. Helped to slightly lift one end of the motherboard so the case can go around the USB power socket. After that it fits back together with only minor persuasion.
Gareth Dart - crwdns2934203:0crwdne2934203:0
Hi,
my Search "button" stop lightning. The other 3 "buttons" are ok.
Did someone know the reason?
Thank you!
timarzoltan83 - crwdns2934203:0crwdne2934203:0
Thanks for help! Real great Guide.
Daniel - crwdns2934203:0crwdne2934203:0
Help! I bought a t5 torx screwdriver to open my motorola and the screwdriver seems too smal! Wtf? Many dismount video says that this is a t5 model, I don't understand...
Pierre Flq - crwdns2934203:0crwdne2934203:0
can you mark ram on that board ?
demon leaks - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 22,419
