crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Mousecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Mechanical Mouse Teardown, Mechanical Mouse Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown, Mechanical Mouse Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown, Mechanical Mouse Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate mouse over and locate Trackball cover
    • Using index fingers and thumb, rotate counter-clockwise
  2. Mechanical Mouse Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the Trackball cover has been rotated, pry the lid off using fingernails.
    • Remove Trackball cover and place to the side.
    • Angle mouse to eject Trackball from the casing.
  3. Mechanical Mouse Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips head screwdriver, locate screw hole and unscrew the screw inside.
    • Lift the two cases apart and place screw to the side.
  4. Mechanical Mouse Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wire from the plastic casing near the top of the mouse.
    • Lift up to remove the PCB which is attached to the mouse.
    • Place case to the side.
  5. Mechanical Mouse Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mechanical Mouse Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate where the wire is connected to the PCB via the white connection.
    • Pry the connections apart and place the cable to the side.
Kevin Gingrich
crwdns2935283:010/06/11crwdne2935283:0
180 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-28, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-28, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G28
Wow! Someone really worked hard on this guide. Kudos sir.
Tushar Varshney - crwdns2934203:0crwdne2934203:0
Yes sir I won't know everything about the machine
mubarak wad gab tagel - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 6,276
