crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Makerbot Digitizercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Makerbot Digitizer Teardown, Remove rear screws and face plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Makerbot Digitizer Teardown, Remove rear screws and face plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Makerbot Digitizer Teardown, Remove rear screws and face plate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are four black T15 screws that hold the front panel on.
    • Do not confuse these with the two laser adjustment screws.
    • The ones you need to loosen are perpendicular with the frame; not angled.
    • Once the screws are loosened, the front panel simply pulls off.
  2. Makerbot Digitizer Teardown, Remove turntable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Makerbot Digitizer Teardown, Remove turntable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Makerbot Digitizer Teardown, Remove turntable: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop the cap out with a flat pry tool.
    • Loosen the T15 screw. You don't need to remove it.
    • Pry on both sides of the turntable so that it comes up and out.
    • To reinstall it, make sure the motor-facing side goes in first, to make good contact with the stepper motor gear teeth.
    • If the stepper motor-facing side does not get reinstalled first, the table will not sit properly.
  3. Makerbot Digitizer Teardown, Remove top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makerbot Digitizer Teardown, Remove top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are eight T15 screws holding the top panel in place.
    • Once these are all loosened, the top panel simply lifts off.
    • Your electronics will look different than mine. Everything should now be accessible.
  4. Makerbot Digitizer Teardown, Inspect the stepper motor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Mine is a 'Moons 14HK2401-74N'.
    • The '74N' seems to indicate the voltage required, in this case, 12V.
Job McKee
crwdns2935283:010/07/12crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 315
