crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Magicshine Seemee 300crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Magicshine Seemee 300 Teardown, Opening the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Magicshine Seemee 300 Teardown, Opening the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Magicshine Seemee 300 Teardown, Opening the back panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The unit has 3 main parts:
    • LED Matrix with the PCB.
    • Metal shell
    • Back plastic plug
    • Both parts are press fit into the metal shell. You will have to use tools to pry it open. Mind the O-rings designated in red
    • I found it easier to use the hook tool and insert it in between the usb-c port and rubber plug loop to get under the plastic.
    • Be mindful of the battery when using anything sharp. There is not much room between the battery and your prying tools
  2. Magicshine Seemee 300 Teardown, Removing the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Magicshine Seemee 300 Teardown, Removing the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery will be glued to the PCB with double sided tape
    • Use your finger or a plastic spudger to carefully peal it off. The adhesive is not strong
    • You will have to desolder the leads to replace the battery
    • Start by desoldering the Ground lead
    • After isolating the Ground lead with a piece of tape, desolder the positive lead
    • The battery is made up of two 802540 lipos wired in parallel
  3. Magicshine Seemee 300 Teardown, To get to the PCB: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Magicshine Seemee 300 Teardown, To get to the PCB: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Magicshine Seemee 300 Teardown, To get to the PCB: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will have to insert two flat spudgers to release the metal clips after which you should be able to press the pcb out of the shell.
    • Bending the usb port PCB a bit, could help prevent damage to the bottom LED
    • Don't rush and keep checking that your applied pressure is not being put through the bottom LED
  4. Magicshine Seemee 300 Teardown, The other side of the PCB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you had water intrusion and you want to get access to the other side of the PCB you will have desolder all 4 contact points
    • It might be difficult soldering them back together as the gap between the pcb and metal frame is just long enough that sometimes solder just stays on both pieces without connecting
    • In that case I would suggest using wick to bridge the gap
  5. Magicshine Seemee 300 Teardown, Reassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Doing steps in reverse should work for the most part. I suggest putting the battery into the plastic back for better alignment of parts. Take care of the battery leads when pressing the back piece into the shell. It's very easy to pinch the wires and you could have a short circuit
multifrag
crwdns2935283:002/24/24crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
Finally someone did it! I see now that I can remove that bottom LED pretty easily. Thank you, mate, appreciate!
Pain Sit.h - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 525
