crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0MTX Terminator TNA251 Car Amplifiercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. MTX Terminator TNA251 Car Amplifier Teardown, MTX Terminator TNA251 Car Amplifier Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let’s take a look at a few of the specs on the MTX Terminator TNA Car Amplifier! It’s:
    • 150 watts RMS x 1 at 4 ohms (250 watts RMS x 1 at 2 ohms)
    • Variable high- and low-pass filters (40-400 Hz, 12 dB/octave)
    • Preamp- and speaker-level inputs
    • Fuse rating: 30A x 2
    • 11-3/4"W x 2-1/4"H x 7-3/16"D
  2. MTX Terminator TNA251 Car Amplifier Teardown, Overview: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MTX Terminator TNA251 Car Amplifier Teardown, Overview: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MTX Terminator TNA251 Car Amplifier Teardown, Overview: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take a general overview of the MTX Terminator TNA252 Car Amplifier.
    • The first thing we notice are all the power and speaker terminals on the right side, then the RCA Line In/Out’s on the left.
    • There is also the EBC Port, Gain, X-over with variable frequency control, and High Level Input (HLI) on the left side of the amp.
  3. MTX Terminator TNA251 Car Amplifier Teardown, Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let’s get started with the actual teardown!
    • Flip the amplifier upside-down, and, using a #2 Phillips Screwdriver, remove the 6 indicated screws.
  4. MTX Terminator TNA251 Car Amplifier Teardown, Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the right side of the amp (power terminal side), use the Allen wrench from the previous step to remove the 9 indicated screws.
    • Be careful not to misplace the screws.
  5. MTX Terminator TNA251 Car Amplifier Teardown, Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the left side of the amp (RCA Side), use an Allen wrench to remove the 5 indicated screws.
  6. MTX Terminator TNA251 Car Amplifier Teardown, Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that we’ve taken all the external screws out, let’s take a look on the inside!
    • All you have to do to get into the inside is lift the back cover off. Easy, right?
  7. MTX Terminator TNA251 Car Amplifier Teardown, Main Circuit Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The internal parts of this Amplifier consist of:
    • Main Circuit Board
    • Transistors
    • Resistors
    • Diodes
    • Capacitors
    • Other components that help amplify, filter, and enhance the sound.
    • CAUTION: Be careful not to spill liquid onto this circuit-board!
    • In this step, I’ll explain how this MTX Terminator TNA252 Car Amplifier works.
    • This amplifier requires an 8 gauge power wire that is connected directly to the battery with a fuse and a ground wire that is connected to the chassis of the vehicle.
    • The amplifier is activated by the remote turn-on wire that is connected to the stereo.
    • The stereo sends audio signals to the RCA input on the amplifier.
    • The audio signals then get filtered and amplified by the internal components of the amplifier.
    • These components include: capacitors, transistors, resistors, X-overs, etc.
    • The amplified audio signals are then sent to the speakers, to put out sound!
  8. MTX Terminator TNA251 Car Amplifier Teardown, Repairing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MTX Terminator TNA251 Car Amplifier Teardown, Repairing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To put back together the MTX Terminator TNA251 Car Amplifier, simply screw in all internal screws (silver screws) using the #2 Phillips Screwdriver.
    • Then, screw in the sides (black hexagon shaped screws) using the Allen Wrench.
    • Finally, place the back cover of the MTX Terminator TNA251 Car Amplifier on top of the sides, and screw the 6 black Phillips screws in using the Phillips Screwdriver.
    • Congratulations - you’ve finished the teardown of the MTX Terminator TNA251 Car Amplifier! Time to shove this amplifier in the back of your car and blast that music!
Ella Nguyen
crwdns2935283:004/09/18crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
Lame write up. All you did is remove the cover and tell what a amplifier does. Not how it works. This was a waste of time article!
James White - crwdns2934203:0crwdne2934203:0
All amplifiers contain transistors resistors and capacitors ????? and also inductors, fuses, connectors, copper, dirt, dust, air, atoms, quarks, and umpaloompas pushing out the electrons.
Thad ward - crwdns2934203:0crwdne2934203:0
Wow! Nice tutorial! I had in mind to repair it but your article allowed me to pimp it into a nuclear thermoblast radio to receive conversation from space! Nice work!!!
joeblack g - crwdns2934203:0crwdne2934203:0
Too funny🤣🤣🤣
Jake break -
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 14,891
