crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Set-Top Boxcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4 circle pads to access the 4 screws. Using a Philips head screwdriver, remove all 4.
  2. M8s OTT TV BOX  Teardown, Remove the bottom: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 M8s OTT TV BOX  Teardown, Remove the bottom: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 M8s OTT TV BOX  Teardown, Remove the bottom: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 circular pads, then using a Phillips screwdriver. Remove the 4 screws.
    • Using the metal spudger in the slits parallel to the Seal you will be able to separate the two piece's.
    • The piece should come off easily.
  3. M8s OTT TV BOX  Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 M8s OTT TV BOX  Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 M8s OTT TV BOX  Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a firm grip at the base of the cable pull up and away from board.
    • Locate the 4 screws, then using the Phillips screwdriver remove them.
    • Before the board can be removed, be sure to use your tweezers to untape the antenna from the housing.
    • The board should come out with ease.
  4. M8s OTT TV BOX  Teardown, Remove the LED board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your Phillips head screwdriver remove the 2 screws that hold the unit to the housing
  5. M8s OTT TV BOX  Teardown, Remove the steel heat plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 M8s OTT TV BOX  Teardown, Remove the steel heat plate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your Phillips head screwdriver, remove the 3 screws that hold it in place.
    • The device has been effectively disassembled.
    • Next I will guide you through a Detailed inspection of the main circuit board.
Austin Pollard
crwdns2935283:002/05/17crwdne2935283:0
1,523 crwdns2915208:0crwdne2915208:0
Reno Phone Repair crwdns2935289:0Reno Phone Repaircrwdne2935289:0
Business
crwdns2942667:0crwdne2942667:0 2,659
