crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Lyve Homecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Lyve Home Teardown, Turn Lyve Home upside down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
  2. Lyve Home Teardown, Remove rubber pad: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This should be easy to remove
  3. Lyve Home Teardown, Remove 4x hex case screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In my case the sticky membrane that glues the rubber to the plastic stayed on the plastic.
    • Remove the 4 hex screws that hold the bottom cover to the case
  4. Lyve Home Teardown, Remove bottom cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover carefully. it should pop right out.
  5. Lyve Home Teardown, Remove main board enclosure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove main board enclosure: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 hex screws attaching the main board enclosure to case
    • Remove connection ribbons that connect to the front LCD screen
  6. Lyve Home Teardown, Remove Mainboard enclosure: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, Remove Mainboard enclosure: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, Remove Mainboard enclosure: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mainboard enclousre from the case by placing your finger in the middle hole and removing it carefully from the case
    • Remove the tape on top of the ribbon connector. this connects to the harddrive
    • Unlock the connector by flipping the lock back to front. this flap is located closets to the heatsink
    • pull the ribbon cable away from the mailboard
  7. Lyve Home Teardown, Remove the harddrive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove the harddrive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive by pulling it out
  8. Lyve Home Teardown, Remove Main board enclosure: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove Main board enclosure: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 hex screws, 2x are holding the main board from the expansion board. 1x is holding the sound and power metal shield and 1 is left holding the expansion board from the enclosure.
    • Remove metal audio/power shield
    • Remove main board from the enclosure board.
  9. Lyve Home Teardown, Remove Main board from Expansion Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove Main board from Expansion Board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the main board carefully away from the expansion board.
  10. Lyve Home Teardown, Remove expansion board from enclosure: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove expansion board from enclosure: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the expansion board away from the enclosure but un clipping it.
    • Its recommended to start from the side with the SD card slot.
  11. Lyve Home Teardown, EXTRA - Board Pictures: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, EXTRA - Board Pictures: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • These are pictures of the main board components under the shielding
    • Qualcomm | PM8921 | AD4J957
  12. Lyve Home Teardown, EXTRA - Board Pictures 2: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, EXTRA - Board Pictures 2: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, EXTRA - Board Pictures 2: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Kingston eMMC 8GB | 240047-002,A00G | 1305 M30231710.10 | KE4CN3H5A
    • Gigabit Ethernet | Atheros | AR8151
    • Broadcom | BCM4339XXUBG
    Is that a JTAG connector on the upper right corner?
    Roland G - crwdns2934203:0crwdne2934203:0
Adonis Sardinas
crwdns2935283:003/03/16crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Excellent!!! Been looking for this for a while. Too bad someone hasn't hacked the firmware or board to make accesible from the USB port. Anyways I guess I can harvest the 2 TB drive. Thanks again
imdfonz - crwdns2934203:0crwdne2934203:0
well done!!! we may need to have video and reusability of the component
or buding software to make local cloud
ALOK CHAUBEY - crwdns2934203:0crwdne2934203:0
I am very interested in a hack. Maybe raspberry pi?
Paul Margraff - crwdns2934203:0crwdne2934203:0
I've been trying to figure out a use for the LCD touchscreen of the Lyve Device.... The LCD seems to be a PJ050IA-01J and when I did a search online I found this: http://www.panelook.com/PJ050IA-14A_Inno...
It seems to be a match other than the -14A vs -01J suffix difference...
If I can just figure out the signal interface it would be nice to reuse the screen with some other device like a Raspberry Pi or even an Intel Compute Stick...
Signal Category : MIPI
Signal Class : MIPI (4 data lanes)
Input Voltage for Panel : 1.8/5.4/-5.4V (Typ.)(IOVCC/VSP/VSN)
Interface Type : FPC
Just found this on aliexpress... it seems that the LCD panel is similar to the one used on Doogee X5 Max cellphones... here's a link for the screen
https://www.aliexpress.com/item/Doogee-X...
However the connector doesn't seem to jive...
Any way to keep using the Lyve Home as a digital photo frame with the photos already on the internal hard drive now that the service has been discontinued and the unit will not link to a wifi signal?
holysmokes6 - crwdns2934203:0crwdne2934203:0
What size hex screws are used on the bottom of the case? I'm trying to find the proper size driver to use.
Ed - crwdns2934203:0crwdne2934203:0
I unscrewed the entire device using a screwdriver T5
revolution90 -
anyone see a JTAG or serial port for this?
Is there any way to make this a normal NAS without needing to login to Lyve? Worst case, remove the HD but it would be better if it can be used with the various ports, RG45 and SD reader.
Larry - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 3,541
