crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Lyve Homecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Lyve Home Teardown, Turn Lyve Home upside down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
  2. Lyve Home Teardown, Remove rubber pad: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This should be easy to remove
  3. Lyve Home Teardown, Remove 4x hex case screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In my case the sticky membrane that glues the rubber to the plastic stayed on the plastic.
    • Remove the 4 hex screws that hold the bottom cover to the case
  4. Lyve Home Teardown, Remove bottom cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover carefully. it should pop right out.
  5. Lyve Home Teardown, Remove main board enclosure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove main board enclosure: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 hex screws attaching the main board enclosure to case
    • Remove connection ribbons that connect to the front LCD screen
  6. Lyve Home Teardown, Remove Mainboard enclosure: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, Remove Mainboard enclosure: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, Remove Mainboard enclosure: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mainboard enclousre from the case by placing your finger in the middle hole and removing it carefully from the case
    • Remove the tape on top of the ribbon connector. this connects to the harddrive
    • Unlock the connector by flipping the lock back to front. this flap is located closets to the heatsink
    • pull the ribbon cable away from the mailboard
  7. Lyve Home Teardown, Remove the harddrive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove the harddrive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive by pulling it out
  8. Lyve Home Teardown, Remove Main board enclosure: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove Main board enclosure: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 hex screws, 2x are holding the main board from the expansion board. 1x is holding the sound and power metal shield and 1 is left holding the expansion board from the enclosure.
    • Remove metal audio/power shield
    • Remove main board from the enclosure board.
  9. Lyve Home Teardown, Remove Main board from Expansion Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove Main board from Expansion Board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the main board carefully away from the expansion board.
  10. Lyve Home Teardown, Remove expansion board from enclosure: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, Remove expansion board from enclosure: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the expansion board away from the enclosure but un clipping it.
    • Its recommended to start from the side with the SD card slot.
  11. Lyve Home Teardown, EXTRA - Board Pictures: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lyve Home Teardown, EXTRA - Board Pictures: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • These are pictures of the main board components under the shielding
    • Qualcomm | PM8921 | AD4J957
  12. Lyve Home Teardown, EXTRA - Board Pictures 2: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, EXTRA - Board Pictures 2: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lyve Home Teardown, EXTRA - Board Pictures 2: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Kingston eMMC 8GB | 240047-002,A00G | 1305 M30231710.10 | KE4CN3H5A
    • Gigabit Ethernet | Atheros | AR8151
    • Broadcom | BCM4339XXUBG
Adonis Sardinas
crwdns2935283:003/03/16crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Excellent!!! Been looking for this for a while. Too bad someone hasn't hacked the firmware or board to make accesible from the USB port. Anyways I guess I can harvest the 2 TB drive. Thanks again
imdfonz - crwdns2934203:0crwdne2934203:0
well done!!! we may need to have video and reusability of the component
or buding software to make local cloud
ALOK CHAUBEY - crwdns2934203:0crwdne2934203:0
I am very interested in a hack. Maybe raspberry pi?
Paul Margraff - crwdns2934203:0crwdne2934203:0
I've been trying to figure out a use for the LCD touchscreen of the Lyve Device.... The LCD seems to be a PJ050IA-01J and when I did a search online I found this: http://www.panelook.com/PJ050IA-14A_Inno...
It seems to be a match other than the -14A vs -01J suffix difference...
If I can just figure out the signal interface it would be nice to reuse the screen with some other device like a Raspberry Pi or even an Intel Compute Stick...
Signal Category : MIPI
Signal Class : MIPI (4 data lanes)
Input Voltage for Panel : 1.8/5.4/-5.4V (Typ.)(IOVCC/VSP/VSN)
Interface Type : FPC
Roland G - crwdns2934203:0crwdne2934203:0
Just found this on aliexpress... it seems that the LCD panel is similar to the one used on Doogee X5 Max cellphones... here's a link for the screen
https://www.aliexpress.com/item/Doogee-X...
However the connector doesn't seem to jive...
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 3,571
