Lunii - My Story Factory v1 - Teardown
  1. Lunii - My Story Factory v1 - Teardown, The right tools.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lunii - My Story Factory v1 - Teardown, The right tools.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lunii - My Story Factory v1 - Teardown, The right tools.: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • STOP! Immediately drop that kitchen knife! Even if you've already opened tons of things with it, it's still not a screwdriver!
    • As a super handyman parent, you do have a real screwdriver hidden at the bottom of a drawer, but until you find it, I'll show you how it goes.
    • For this, I'm going to use a size 2 Phillips (or Phillips PH2) screwdriver. A 3.5 dish will do just fine, all this and being able to reach the screw without damaging the hull of our Lunii.
  2. Lunii - My Story Factory v1 - Teardown, 4 screws, nothing more.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lunii - My Story Factory v1 - Teardown, 4 screws, nothing more.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let's go ! We firmly hold our Story Factory in one hand and with the other we unscrew the 4 screws that come our way.
    • Make sure that the 4 screws are fully unscrewed by tilting the Lunii, they will fall out by themselves.
  3. Lunii - My Story Factory v1 - Teardown, Inhale, pull!: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lunii - My Story Factory v1 - Teardown, Inhale, pull!: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lunii - My Story Factory v1 - Teardown, Inhale, pull!: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then straighten the Lunii and hold the two top edges each with a thumb.
    • By gently spreading your fingers you should be able to open it without any resistance.
    • Hooray we made it! And a small interesting detail, the adhesive under the Lunii acts as a hinge.
  4. Lunii - My Story Factory v1 - Teardown, Admire: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lunii - My Story Factory v1 - Teardown, Admire: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next step: make an inventory of common failures and their solution!
To reassemble your device, follow the instructions in reverse order.
Be careful not to overtighten the screws, you risk breaking their plastic support!
crwdns2935229:019crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0Mr. Stampscrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Martial B
crwdns2935283:009/08/12crwdne2935283:0
1,067 crwdns2915208:0crwdne2915208:0
crwdns2947412:019crwdne2947412:0
Peut etre mais sur sur la “mienne” ce n’est pas un embout PH2 qu’il faut utiliser , mais plutôt d’un embout hexagonal !!
jacobi - crwdns2934203:0crwdne2934203:0
C’est des embouts Torx de taille 6 sur la mienne. Avec un tournevis de precision et une clef pour amorcer le dévissage, ça l’a fait sans trop de difficulté.
Ma version est de 2020, et l’intérieur n’a en fait rien à voir…
Merci d’avoir initié le sujet !
Florent Moriceau - crwdns2934203:0crwdne2934203:0
bonjour
merci Florent, c’est bien du Torx n°6, sans ton commentaire je n’aurai pas su quoi commander comme outils.
Par contre l’électronique est en petite taille, à par la carte mémoire et changer la batterie, aucune réparation n’est possible. Moi je n’ai plus de son que d’un côté dans le casque et rien sur le Haut parleur, je ne peux pas réparer.
cdt
hugues tellier - crwdns2934203:0crwdne2934203:0
il faut bien un torx n°6 mais certain 6 sont trop petits et tournent dans le vide j'ai finis par trouver le bon dans ma boite tivoly. Après, ma panne était le commutateur d'histoire (gros bouton jaune) qui était dessoudé 6 soudures à refaire plus un peu de colle pour éviter la récidive et tout fonctionne
christian RAUSCH 02/04/2022
pensees695 - crwdns2934203:0crwdne2934203:0
Bonjour
j'ai le même problème de la petite pièce à ressouder. Pourriez vous m'indiquer dans quel sens il faut la mettre (le zéro en haut ou le zéro en bas)? et quel matériel utilisez vous pour souder? Merci beaucoup
fp pic -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 108
crwdns2936753:030crwdne2936753:0 431
crwdns2942667:0crwdne2942667:0 46,184
