Logitech M705 Teardown
  1. Logitech M705 Teardown, Logitech M705 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First of all You have to remove battery
  2. Logitech M705 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech M705 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the screws under the label
    • Unscrew the single screw below the USB-dongle space
  3. Logitech M705 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under the rubber on the top of the mouse there are other screws
  4. Logitech M705 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I had a problem with the right click: I solved with a shim on the little switch
    • Here we are!
crwdns2935229:050crwdne2935229:0
Francesco Palmisano
crwdns2935283:012/02/15crwdne2935283:0
1.310 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
1) There is an additional screw that is already removed on the first picture : under the USB stick emplacement.
2) It is not necessary to remove the rubber. Just peel it with something thin, because the screws are very lateral
3) Be careful while disassembling the top, it is plugged to the base by a 3 wires connector (white/red/black on the Step 4 picture).
Philippe Puech - crwdns2934203:0crwdne2934203:0
Nice simple guide. I used it to quickly take apart a M705 where the laser stopped working after it fell. I didn't do more than reseat the connector cable, but it seems to work again now !
Philippe Puech's comments are good. In fact I wished I'd noticed his 2) before removing the rubber, as the lower layer distorts and doesn't fit back well on a complete removal. His comment puzzled me at first, and might be better phrased as "Peel back the rubber from each side to expose the Left and Right retaining screws. "
A screw bit labelled PH1 (Philllips Head 1) seemed to fit the screws well.
Epee Sharkey - crwdns2934203:0crwdne2934203:0
Hello, I recently bought used m705. but it wont turn on even if i change the battery. is there anyway i can fix this?
Thank you.
eekj97 - crwdns2934203:0crwdne2934203:0
Anybody knows if there's a replacement for laser sensor available?
Danyil - crwdns2934203:0crwdne2934203:0
great thanks.. just to clarify you screw right through the lable.. no need to remove it. that got me stuck for a while.
now
David Miller - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 70
crwdns2936753:030crwdne2936753:0 313
crwdns2942667:0crwdne2942667:0 40,249
