crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Linksys Velop WHW01crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Linksys Velop WHW01 Teardown, Unclip the top cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys Velop WHW01 Teardown, Unclip the top cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Jimmy
    $7.95
    • To unclip the top cover, insert a Jimmy at the seam and pry upwards.
  2. Linksys Velop WHW01 Teardown, Unscrew the outer case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys Velop WHW01 Teardown, Unscrew the outer case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    T6 Torx Screwdriver
    $9.99
    • Use a Torx T6 screwdriver to unscrew the two screws that were previously hidden under the top cover.
  3. Linksys Velop WHW01 Teardown, Remove the rubber strips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the rubber strips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Spudger
    $2.99
    • Use a Spudger to peel off the rubber strips at the base.
    • Make sure to not tear them apart.
  4. Linksys Velop WHW01 Teardown, Unscrew the base: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Unscrew the base: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Unscrew the base: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    T6 Torx Screwdriver
    $9.99
    • Use a Torx T6 screwdriver to unscrew the four screws that were under the rubber feet.
    • After removing the screws, the bottom cover can be lifted off.
  5. Linksys Velop WHW01 Teardown, Remove the outer cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the outer cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the outer cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pinch and pull up on the internal plastic bracket.
    • The main board, antenna and LED assembly should slide out without any force needed.
  6. Linksys Velop WHW01 Teardown, Remove the port cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the port cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the plastic surrounding the power input and ethernet ports.
    • You may need to give it a jiggle to come loose.
  7. Linksys Velop WHW01 Teardown, Unclip the WiFi antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $2.99
    • Unclip the WiFi antennas from the main board.
    • Use a Spudger to not cause any damage, these connectors can be very fragile!
  8. Linksys Velop WHW01 Teardown, Unscrew the antenna bracket: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Phillips #00 Screwdriver
    $5.49
  9. Linksys Velop WHW01 Teardown, Slide out the LED module: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Slide out the LED module: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Slide out the LED module: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the LED module out of the groove its slid into.
    • Be careful with the highly fragile ribbon cable, it is soldered on the LED and main board and does not detach!
  10. Linksys Velop WHW01 Teardown, Remove the antenna bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the antenna bracket, being mindful of the LED module.
  11. Linksys Velop WHW01 Teardown, Unclip the bluetooth antenna: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the Bluetooth antenna, the same procedure as the WiFi antennas.
  12. Linksys Velop WHW01 Teardown, Remove the plastic bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the plastic bracket: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the plastic bracket: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $5.49
    • Use a Phillips #00 Screwdriver to unscrew the screw holding the rear plastic bracket.
    • Turn the assembly around and lift the bracket off the main board.
  13. Linksys Velop WHW01 Teardown, Remove the front heatsink: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the front heatsink: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys Velop WHW01 Teardown, Remove the front heatsink: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $5.49
    • Use a Phillips #00 Screwdriver to unscrew the three screws securing the heatsink.
    • After removing the screws you will need to twist it side to side a little bit due to the thermal pad.
  14. Linksys Velop WHW01 Teardown, Remove the back heatsink: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the upper heatsink, the heatsink on the back of the board can be removed using a similar process to the top heatsink.
    • Only small and gentle side to side movement is needed to release the thermal pads.
Lewis L. Foster
crwdns2935283:007/31/18crwdne2935283:0
266 crwdns2915208:0crwdne2915208:0
Very well done! In terms of disassembly, how long did it take to get everything apart?
Jacob Mehnert - crwdns2934203:0crwdne2934203:0
definitely no longer than 10 mins, even shorter if you are only going in to access the serial port for flashing a custom firmware
Lewis L. Foster -
Great information, thank you for doing this! Did I see a proprietary antenna connector and no ts9?
Courtney Glenn - crwdns2934203:0crwdne2934203:0
Not really clued up on my antennas so not sure
Lewis L. Foster -
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 92
crwdns2942667:0crwdne2942667:0 4,691
