crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Lenovo B50-80crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Lenovo B50-80 Teardown Guide, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the switches to the unlocked position then push the battery out
  2. Lenovo B50-80 Teardown Guide, Service Door Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo B50-80 Teardown Guide, Service Door Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two screws (outlined in red) holding the service door in place. Remove these and slide the door off.
    • Under the service door, you will see the hard drive, CMOS battery, WiFi card, and RAM.
  3. Lenovo B50-80 Teardown Guide, Optical Drive Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the highlighted screw, then slide the optical drive out.
    • Lower-specced laptops may only have a plastic placeholder for the optical drive.
  4. Lenovo B50-80 Teardown Guide, RAM, Hard Drive, and CMOS Battery Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For the hard drive, remove the highlighted screws and lift and remove the hard drive out.
    • Next, take a plastic spudger, put it under the CMOS battery, and pry it out.
    • Then, pull the sides on the RAM stick(s) and remove them.
  5. Lenovo B50-80 Teardown Guide, Keyboard Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The keyboard can be removed from the frame once the three retaining screws (circled in red) have been removed.
    • Once screws have been removed, pop out the keyboard carefully with a spudger and unplug the ribbon cable attaching it to the motherboard.
  6. Lenovo B50-80 Teardown Guide, Keyboard Bezel Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo B50-80 Teardown Guide, Keyboard Bezel Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To start, remove the 12 highlighted screws.
    • Next, disconnect & unroute the FPC connectors highlighted in blue.
    • Then with a plastic spudger tool, go around the edge of the bezel and pop all the plastic clips.
    • Lift the bezel out.
  7. Lenovo B50-80 Teardown Guide, I/O Board Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the highlighted flex cable from the motherboard, then peel it up from the casing.
    • Remove the highlighted screw on the right, then simply pull the board and cable out of the system.
  8. Lenovo B50-80 Teardown Guide, UltraBay Connector Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the flex cable from the motherboard and then remove the two highlighted screws, and then pull it out.
  9. Lenovo B50-80 Teardown Guide, Charge Status LED Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the highlighted flex cable, then gently remove the cable and the LED.
  10. Lenovo B50-80 Teardown Guide, Motherboard Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 highlighted screws
    • Pull the motherboard up and out
  11. Lenovo B50-80 Teardown Guide, Power Cable Removal: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the white nub out with a spudger to remove the charging cable.
  12. Lenovo B50-80 Teardown Guide, Cooling Fan Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan cable from the motherboard
    • Remove the one screw that holds the fan in place.
  13. Lenovo B50-80 Teardown Guide, Speaker Removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Un-route the speaker cables (highlighted in blue).
    • Remove the retaining screws (circled in red) and pull out the speakers.
  14. Lenovo B50-80 Teardown Guide, Display Assembly Removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Un-route the antenna cables (highlighted in red)
    • Remove the 6 retaining screws (circled in blue).
    • The display will then be able to be slid out and removed from the rest of the body.
  15. Lenovo B50-80 Teardown Guide, Display Bezel Removal: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this point, the display bezel is able to be popped out.
    • Use a thin piece of plastic to wedge it open if necessary.
    • Be careful not to snap the bezel in the process!
  16. Lenovo B50-80 Teardown Guide, Display Panel Removal: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 12 retaining screws (circled in red) and carefully pull out the display panel.
    • Be mindful of the connector cable.
    • Flip the display over and remove the connector cable.
    • It should slide out easily.
    • The hinge can also now be removed.
  17. Lenovo B50-80 Teardown Guide, Camera Removal: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The camera will be at the top of the display.
    • With a plastic tool, carefully pull up the wire on the top.
    • The camera is now able to be popped out.
    • Disconnect the connector cable and remove the camera from the display.
  18. Lenovo B50-80 Teardown Guide, Final Result: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
crwdns2935103:0crwdne2935103:0
Ian Steiger
crwdns2935283:006/12/19crwdne2935283:0
377 crwdns2915208:0crwdne2915208:0
Thanks man, was really helpful.... Not from repair-friendly ones
Pavel Bykov - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,853
