crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0LG Optimus L9 P769crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. LG Optimus L9 P769 Teardown, LG Optimus L9 P769 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus L9 P769 Teardown, LG Optimus L9 P769 Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here's what LG's L9 P769 holds hardware-wise:
    • Dual-core 1.0 GHz CPU
    • 4.5 inch IPS LCD with a resolution of 540 x 960 pixels
    • 4 GB of internal storage
    • 5MP Primary camera and VGA front facing camera
    • Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, hotspot, DLNA
  2. LG Optimus L9 P769 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the device and gently lift the battery cover off to access the battery
  3. LG Optimus L9 P769 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery from the notch in the edge of the battery compartment
  4. LG Optimus L9 P769 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using the PH000 headtype
  5. LG Optimus L9 P769 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  6. LG Optimus L9 P769 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove vibration and speaker module using the prying tool
  7. LG Optimus L9 P769 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove both connections of the antenna by pulling up with tweezers
  8. LG Optimus L9 P769 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  9. LG Optimus L9 P769 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  10. LG Optimus L9 P769 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screw at top of phone to release speaker with PH000 screwdriver
  11. LG Optimus L9 P769 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small prying tool to release all motherboard connections.
  12. LG Optimus L9 P769 Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove rear facing camera by using the small prying tool
  13. LG Optimus L9 P769 Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the motherboard with small prying tool to remove and set aside
  14. LG Optimus L9 P769 Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
    • Do not force open as the latches attaching the digitizer to the chassis as they are easily damaged.
  15. LG Optimus L9 P769 Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the digitizer from case by sliding out connected ribbon cable
  16. LG Optimus L9 P769 Teardown: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a small prying tool to detach the screen circuitry from the case
  17. LG Optimus L9 P769 Teardown: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the remaining circuitry utilizing a smaller prying tool or a small flathead screwdriver
    • Carefully slide out circuity to remove phone display
  18. LG Optimus L9 P769 Teardown: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to disconnect the 3.5mm headphone jack from the phone
  19. LG Optimus L9 P769 Teardown: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus L9 P769 Teardown: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  20. LG Optimus L9 P769 Teardown: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Full tear-down and recommended tools for procedure
Kayden G
crwdns2935283:003/01/17crwdne2935283:0
272 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G1, Harley Spring 2017 crwdns2935289:0IUPUI, Team S2-G1, Harley Spring 2017crwdne2935289:0
IUPUI-HARLEY-S17S2G1
crwdns2942667:0crwdne2942667:0 1,928
