crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Kyocera Risecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Kyocera Rise Teardown, Kyocera Rise Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Rise Teardown, Kyocera Rise Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Teardown of Kyocera Rise
  2. Kyocera Rise Teardown, Removing the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Rise Teardown, Removing the Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First remove the back cover to expose the battery
    • Next pull the battery from the phone
  3. Kyocera Rise Teardown, Removing White Sticker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Rise Teardown, Removing White Sticker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white sticker to expose the black plastic tab that is covering the ZIF connector that is connecting the flex cable that goes between the motherboard and screen
  4. Kyocera Rise Teardown, Peeling Away Black Tab: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Peeling Away Black Tab: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Peeling Away Black Tab: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black tab by first getting under it with something sharp like an exact knife
    • It's adhered with a weak adhesive and peels away easily
    • As you can see a hole was left open to specifically allow quick and easy mate/unmate of the ZIF connector
  5. Kyocera Rise Teardown, Removing Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Rise Teardown, Removing Screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all six screws using a Phillips # 0 (PH0) screwdriver
  6. Kyocera Rise Teardown, Disconnecting ZIF: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Disconnecting ZIF: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Disconnecting ZIF: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the ZIF (zero insertion force connector) by running a pair of Blunt Tweezers underneath it. Twist and pull, this causes the black latch that's holding down the flex cable to open and then the flex cable can be pulled out of the ZIF with the Tweezers.
    • Since the screws were removed the phone's keyboard containing half can be lifted away from the screen.
  7. Kyocera Rise Teardown, Peeling Away The Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Peeling Away The Keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Peeling Away The Keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the phone so that the keyboard is facing you
    • The keyboard is flexible and can be peeled away from the body of the phone
    • The keyboard is latched in about 6 places and can peeled away slowly and carefully. It is not held down with adhesive.
  8. Kyocera Rise Teardown, Removing the Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Removing the Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Removing the Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 screws again using the Philips #0 screwdriver. This will allow you to pull out the motherboard from the back housing
  9. Kyocera Rise Teardown, Motherboard and Chips: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Motherboard and Chips: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Motherboard and Chips: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The metal shielding was difficult to unscrew and the screws were all stripped in the process. Using a needle nose plier, the metal shielding was torn away
    • The exposed motherboard is shown here along with microscope pictures of the chips.
    • Chip #1
    • Chip #2: 1 GHz Qualcomm processor PM8058
  10. Kyocera Rise Teardown, Motherboard and Chips: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Motherboard and Chips: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Motherboard and Chips: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Chip #3: Qualcomm CDMA antenna driver QTR8615
    • Chip #4: Samsung 2 GBit memory
    • Chips #5
  11. Kyocera Rise Teardown, Removing Antenna Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Removing Antenna Assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Rise Teardown, Removing Antenna Assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the motherboard the back housing can then be disassembled. The volume rocker and the power button slide out of the back housing without any effort
    • The upper antenna assembly is held in place only through a "snap into place" mechanism. It can be removed by apply a little prying pressure with end of a tweezer at the locations indicated with arrows
  12. Kyocera Rise Teardown, Lower Antenna Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The lower antenna assembly can be similarly removed by applying a little pressure to pop it out of the assembly
  13. Kyocera Rise Teardown, Antennas and Housing: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Rise Teardown, Antennas and Housing: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Both sides of the back assembly and antenna assemblies are shown here
alcs99
crwdns2935283:009/10/13crwdne2935283:0
5 075 crwdns2915208:0crwdne2915208:0
You didnt describe how to disassemble the front panel with the touchscreen.
Mark Laxmeter - crwdns2934203:0crwdne2934203:0
It would be useful to consider adding in the size of the screws removed, in case of misplacement. Also, since those screws tend to fall out over the course of normal phone usage
Thomas Leman - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 6,099
