Turn the printer face-down so the bottom is showing. Use a PH002 screwdriver to remove the three screws.
Turn the printer so the back-side is showing. Use a PH00 screwdriver to remove the two screws.
Slowly lift the top of the printer until the top panel detaches from the base.
Carefully turn the top panel to expose the three screws on the green chip. The ribbons are flexible, but do not twist them excessively.
Use a PH00 screwdriver to remove the two screws on the green chip.
