JBL Charge 2 Partial Teardown
crwdns2936621:0crwdne2936621:0
  1. JBL Charge 2 Partial Teardown, Remove Protective Mesh: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 2 Partial Teardown, Remove Protective Mesh: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger/spatula, credit card or something similar to remove the protective mesh.
    • There is a little bit of glue holding the mesh in place. Even so, be careful to not use too much force when removing the mesh to avoid causing damage.
  2. JBL Charge 2 Partial Teardown, Remove Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 2 Partial Teardown, Remove Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws holding the plastic moulding on the end of the speaker.
    • Next, remove the plastic to reveal four more screws requiring removal.
  3. JBL Charge 2 Partial Teardown, We're in!: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 2 Partial Teardown, We're in!: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You now have access to the motherboard.
    • To make life easier, disconnect the microphone before disconnecting the battery.
  4. JBL Charge 2 Partial Teardown, Removing the Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 2 Partial Teardown, Removing the Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws securing the white battery cover. Once removed, you will have direct access to the battery.
    Nice tutorial on how to dismantle the device, but what if I want to separate out the power bank part of this device and dump the rest due to worn out speakers. Is it possible to do that? If not, will it still work as a power bank if I simply the wires to the speakers and remove them. I’d rather remove the amplifier as well so that unnecessary power consumption is reduced.
    David Moody - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Alexandre Isaac
crwdns2935283:004/07/13crwdne2935283:0
2,997 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
About to try this, will give feedback
Rick Purchase - crwdns2934203:0crwdne2934203:0
This is the charge2 + not the charge2
The Daniel - crwdns2934203:0crwdne2934203:0
there aren,t any screws in the cap
Norman Ingham - crwdns2934203:0crwdne2934203:0
I have the same problem. I think this is a TL model, but I have not been able to find any information on how to correctly remove the end caps. I don’t want to scratch or break anything trying to pop the end caps off.
Bobcov -
Thanks so much! I had a broken bit of plastic inside the tube after I left my speaker in my checked luggage and it got smashed around. I followed the instructions and managed to get it out, the speaker is purring again without the annoying ass rattle!! You're a legend my friend. TY
itgotfixed - crwdns2934203:0crwdne2934203:0
You are welcome !
Alexandre Isaac -
Hello, I have a problem
I lost the speaker screws
can you tell me what type of screws I have to buy?
thank you in advance
bilal mesrour - crwdns2934203:0crwdne2934203:0
Ce tuto ne concerne PAS le charge 2, mais bien le charge 2+
Le principe d’ouverture est bien différent !
jf.dedecker - crwdns2934203:0crwdne2934203:0
So easy steps to follow. Thank you so much. The guide is really helpful.
It came handy when my boss complained about a fault, so I tried figuring it out, then I googled steps to dismantle, and pop! The video showed up. Really helpful. Thanks
omo4rmzion - crwdns2934203:0crwdne2934203:0
This tutorial really helped :)
JITHIN ROY - crwdns2934203:0crwdne2934203:0
Bonjour à tous, je constate que sur ce tuto on a des personnes qui gèrent donc bcp d'amitié
et de remerciement à tous vous êtes tjrs en mode cool et ça fait vraiment merci et n'hésitez pas à me demander un service
je serai fier de vous rendre service et encore merci Thameur
Thameur TRABELSI - crwdns2934203:0crwdne2934203:0
comme vous l'avez sans doute compris "bcp plaisir"
crwdns2936753:030crwdne2936753:0 122
crwdns2942667:0crwdne2942667:0 52,961
