Still mostly barred from Google services, Huawei has given their Mate-series smartphones another go with the Mate 40 Pro, enticing would-be buyers with unbeatable specs and shiny new silicon. We wanted to spend a little more time with the Mate before deciding whether or not it is indeed a friend of ours. And by spend time, of course, we mean tear down.
Be the very first to know when the newest consumer tech hits the teardown table—follow iFixit’s YouTube channel, Instagram, or Twitter, and subscribe to our newsletter.
These days, a smartphone can't compete on specs alone. But that won't stop anyone trying—and the Mate 40 Pro certainly tries. Our teardown unit includes:
Kirin 9000 octa-core SoC with integrated 5G modem and 24-core Mali-G78 MP24 GPU
6.76-inch OLED display with 1344 × 2772 resolution, 90 Hz refresh rate, and HDR10
Triple rear camera setup with 50 MP ƒ/1.9 wide, 12 MP ƒ/3.4 periscope zoom, and 20 MP ƒ/1.8 ultra-wide modules, and Leica optics
256 GB internal storage plus Nano Memory expansion for an additional 256 GB
"Sub-6" 5G connectivity, Wi-Fi 802.11ax 2x2 MIMO, Bluetooth 5.2
66W fast charging, 50W fast wireless charging, and 5W reverse wireless charging
3D Face Recognition, optical under-display fingerprint sensor, and gesture controls
Let's do a quick visual comparison of the Mate 40 Pro to its Mate 30 Pro predecessor before examining its internal friendliness. What's new?
The Halo Ring camera array has migrated, grown an integrated single-LED flash, and been renamed Space Ring.
The Mate 40 Pro loses one front-facing camera, and the remaining two now hang out in an elongated hole-punch at the top left corner of the screen.
Despite the heavy curvature of its screen, the Mate 40 Pro has physical volume and power buttons clinging to a sliver of frame on the right edge. Additionally, there's a lefty-friendly "virtual button" on the opposite side.
Finally, a speaker grille at the top suggests the Mate 30 Pro's screen-vibrating speaker driver didn't make the cut this year.
crwdns2935267:0crwdne2935267:0iMac Opening Wheel$7.99
Our usual procedure of heating, lifting and slicing doesn't go exactly to plan today: the adhesive refuses to budge under our suction cup. But the gap between the rear glass and the midframe is just wide enough for our iMac Opening Wheel to slice into.
There were no hidden cables to accidentally slice when opening the Mate 30 Pro, and since the 40 Pro also sports an under-display fingerprint reader, we expect no booby traps here. Reader, we were wrong.
Apart from that slightly disappointing setback, our entry is successful! Inside we see the thick adhesive strips that gave us a hard time, and the four unblinking eyes in the Space Ring. Most of our view at this point is blocked by shields and the wireless charging coil.
Not to play favorites, but we must admit this first look is less tidy than the clean new iPhone lineup.
crwdns2935267:0crwdne2935267:0Marlin Screwdriver Set - 5 Standard Precision Screwdrivers$19.99
The first component to come loose is not the motherboard shield or charging coil, but the flash sensor assembly.
Next, our Marlin Screwdriver Set dispatches some Phillips screws and we get our first glimpse at
machine citythe motherboard.
We can now pull a few square camera modules from their home in the round Space Ring.
Here are the Mate 40 Pro cameras laid bare:
50 MP, ƒ/1.9 wide camera (23 mm) with a 1/1.28" RYYB pattern Sony IMX700Y sensor (1.22 µm pixel size)
By comparison, the new wide sensor in the iPhone 12 Pro Max touts a 1.7µm individual pixel size, albeit at lower res.
12 MP, ƒ/3.4, telephoto camera (125 mm) with 5x optical zoom and OIS featuring an RYYB pattern Sony IMX351Y sensor
20 MP, ƒ/1.8, ultrawide camera (18 mm), featuring an RGB pattern Sony IMX718 sensor
crwdns2935267:0crwdne2935267:0Spudger$3.99
Like most smartphones, the Mate 40 Pro motherboard has a whole bunch of flex and antenna cable friends at this party, most of them inconveniently blocking our way to the silicon bar.
With the help of a full squad of spudgers and tweezers we plow through the crew, stumbling over the selfie cam halfway through:
13 MP, ƒ/2.4, ultrawide (18 mm), Sony IMX688 sensor (1.22 µm individual pixel size)
2 MP ToF camera for 3D depth and biometrics
The bottom third comes out next: these cables and components might not be flashy, but they all have one great thing in common: modularity.
Betwixt all those cables, we have a fairly standard lower-half-of-a-smartphone situation on our hands here: SIM tray, small daughterboard, loudspeaker (32-bit/384 kHz), and some shielding.
I feel like the width of usb flex cable helps with the dissipation of the heat generated by pushing 66w trough it
Reaching the battery, we are quite happy to see that Huawei has stuck to its pumpkin
flavoredcolored pull tabs, which allow for heatless battery removal. -
The Li-Ion battery in the Mate 40 Pro is 16.94 Wh (4400 mAh, 3.85 V)—slightly less capacity than the 17.32 Wh (4500 mAh, 3.85 V) cell we found in the Mate 30 Pro.
Those two connectors are very likely two separates routes for electrons coming in via a wire vs. those coming in through the air as seen in the iPhone 11 Pro.
The Mate 40 Pro can also dole out 5 W to another device via reverse wireless charging.
Now that we've removed nearly everything else, we can finally make that trip to the silicon bar. Here's what's on tap today:
Samsung KLUEG8UHDB-C2E1 256GB UFS 3.1
A never-before-seen Chengyan K3LK3K30EM-CGCN LPDDR5 SDRAM from SEC (Samsung Electronics Corporation) layered over the 5 nm Kirin 9000 5G SoC with octa-core CPU (1x3.13 GHz Cortex-A77 & 3x2.54 GHz Cortex-A77 & 4x2.05 GHz Cortex-A55) & Mali-G78 MP24 GPU
HiSilicon Hi1105 Wi-Fi 6 module
HiSilicon Hi6365 RF Transceiver (as seen in the Mate 20x)
HiSilicon Hi6525 Power management (top) and HiSilicon Hi6D05 Power amplifier (bottom)
Dot projector
On the flip side we find some more HiSilicon and some mystery chips:
HiSilicon Hi6421 and Hi6423 Power management IC (as seen in the Mate 20x)
HiSilicon Hi6D05 Power Amplifier Module
6S03V100 2029S13 0022
438 AkLNA 120514
6H12 V1GP1 63024/V1HP510025
Most of the connectors are soldered onto the motherboard as the second layers only reveal contact points underneath.
- The green framed ICs (438 AkLNA 120514 + 446 XnAWB 040039) are quite likely from Murata (> according to the Teardown of de Mate 30 Pro of TechInsights…)
- The light blue framed ICs (6H12 V1GP163024 + 6H12 V1HP510025 + 6H12 V1HP510025) are from HiSilicon (Huawei Subsidiary)
- Pretty obviously, the Chengyan K3LK3K3 is produced from SEC (Samsung Electronics Corporation)
- The two most interesting facts:
1. no components of a US company like Skyworks, Qorov, Qualcomm, Cirrus Logis, TI, …)
2. a lot of the HiSilicon IC’s are - for the first time - produced in mainland China (Shortcut: “CN” at the end of the type description)
Question: Can you give us more details about the fingerprint sensor (Goodix or Synaptics) ? My guess is Goodix (‘cause it’s extraordinarily flat > perhaps “Goodix Ultra-Thin…” like in the P40 Pro that’s has the pritty much same PCB design)
Hi Ai Lang,
thanks for your comment and chip IDs. I’d say its likely a Goodix fingerprint sensor. However I removed a metal shield next to the fingerprint connector and the number on the chip says “GD L4CE 2015”. Didn’t really find anything else but maybe it helps you to exactly identify.
6H11/6H12 are Hi6H11/Hi6H12, Low Noise Amplifier designed by HiSilicon
Hi Dominik,
after a lot of research, you can add your description as follows:
yellow point: USI (likely) 6S03V100 (purpose: unknown)
green point: Murata 438 AkLNA Low Noise Amplifier (probably low-band) [dt. Leistungsverstärker]
blue point : HiSilicon Hi5H12 + Hi6H12 LNA/RF Switch
furthermore (not framed on your foto): HiSilicon Hi6H11 LNA/RF Switch (maybe you can frame it blue like the other LNA/RF Switches above)
furthermore (not framed on your foto): Murata 446 XnAWB Wideband Amplifier (mid- and highband) [dt. Leistungsverstärker]
I can identify some chips as below:
1. 438 AkLNA 120514 : Low band FEMid, integrate Switch and filter( SAW, Duplexer, Quaplexer…)
2. 446 is Middle and high band FEMid
3. 6H11 is Low band LNA bank
4. 6H12 is Middle and High band LNA bank
5. 429 is PA module of N77/79
Our friendship test is nearly finished, but let's fish out the final remaining components.
First on the hook is a second speaker along the top edge of the phone, doing double duty as both an earpiece speaker and a second loudspeaker for stereo sound in landscape mode.
The second catch is the tiny linear actuator vibration motor. Since we've still got all these iPhones laying around, here's a comparison:
The last components in the net are a proximity sensor, a power and volume button cable, and one last interconnect cable.
For our last trick, we'll attempt to remove this 88° curved 6.76" screen.
First, we treat the screen with copious amounts of heat. After several minutes of hard work, we manage to press our iMac Opening Wheel under the screen … only to watch the glass immediately shatter.
We knew going into this that curved displays were a nightmare to remove, but even we were not prepared for how terrible this one would be. No thanks, Mate.
We refuse to surrender after coming so close to full disassembly. After a few more cracks and plenty of cursing and prying, we manage to peel back the display. Ta-da!
No matter which way you cut it (and boy did we cut it), display replacements for the Mate 40 Pro will be horrible. Can't say we're surprised—just disappointed.
With a final weary sigh, we remove the under-display fingerprint sensor. There's no way to replace this part without removing the screen, so... let's hope it doesn't break.
After the display debacle, our journey with the Mate 40 Pro comes to a somber end. Just like that, its many components lie peacefully in front of us, ready for our final judgement.
Though it was eager to befriend us, the Mate 40 Pro turned out to be hiding some unpleasant secrets.
Its relative modularity and battery pull tabs are heartwarming, but booby trap cables and a disorganized design are the first drops of rain on the parade. The downpour starts when you get to the display though. No critical component should be that difficult to replace.
Let's find out just how friendly this Mate will be to its future owners! Keep scrolling to see our repairability score.
- Huawei uses standard Phillips screws throughout the phone.
- All major components are modular enough to be accessed/replaced independently... if not easily.
- Pull tabs make the battery removal easier, but you'll have to work your way through plenty of cables and covers first.
- Glass on front and back doubles the likelihood of drop damage.
- The display adhesive is insanely strong.
- The display can't be replaced without removing the battery, and the under-display fingerprint reader can't be replaced without removing the display.
crwdns2935195:0crwdne2935195:0
crwdns2935097:0crwdne2935097:0
crwdns2935199:0crwdne2935199:0
crwdns2944067:07crwdne2944067:0
And the teardown of the ps5?
Can you also separate the dual-layers mainboard?
Hi Cheney Xian, I added a photo of the dismantled board in step 10.
Is it truely RYYB(x5 tele)? Huawei doesn’t say whether telephoto camera is RYYB or not. Do you have any basis?
Can you say if the Kirin 9000 is pop package?
How much does the battery weight please?
Which HW version of this phone? As I know, the China Version is NOH-AN00.
xiajinggai - crwdns2934203:0crwdne2934203:0
Hi xiajinggai, thanks for your question. The model we used for the teardown in Europe was: NOH-NX9.
Dominik Schnabelrauch -
