crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0HTC Evo 3Dcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. HTC Evo 3D Teardown, HTC Evo 3D Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First things first, Remove the back cover, battery and SD card.
  2. HTC Evo 3D Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four T5 Torx screws.
    • Then remove the two Phillips screws.
    • *Very sorry for dark image*
  3. HTC Evo 3D Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
    • Begin from the bottom were the battery bay is, It is the easiest way.
    • Be careful of ribbons behind the plastic
  4. HTC Evo 3D Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Evo 3D Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Evo 3D Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
  5. HTC Evo 3D Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Evo 3D Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
    • Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
    • Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
    • Tuck the ribbons in without bending or making tears in them.
  6. HTC Evo 3D Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Behind the main board is two more ribbon's.
    • Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
    • Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
    • As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
  7. HTC Evo 3D Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This concludes the (simple) teardown of the Evo 3D.
_Z_
crwdns2935283:003/18/12crwdne2935283:0
9.698 crwdns2915208:0crwdne2915208:0
Android Alliance crwdns2935289:0Android Alliancecrwdne2935289:0
Community
crwdns2931471:092crwdne2931471:0
crwdns2935297:0747crwdne2935297:0
Thanks. This was very helpful.
dano706 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 19,607
