crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0HTC Desire 626Scrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    • The tools you need are something to pry the frame open and two screw drivers one philip and one security torx
    • Start with opening the back of the phone
    • Then unscrew the 7 screws that are around the frame of the phone and don't forget the one screw thats in the middle
    • Pry frame open with these tools and don't force it or you may snap your frame
    • Then your going to take the battery outbid gently pulling upward on the wires that is connected to the white piece of plastic
    • then you going to take the the strip on the left hand side of the phone and pull it out with you fingers
    • then you take out the strip that is on the right side of the strip u just took out. (Use fingers)
    • Then you then you pick up the top phone chip and go to the bottom of it to take out the black strip which is the last one.
    • then take the bottom rectangle chip and take it out with the top square chip keep the black wire on the chips cause its hard to put back on
    • Then take out the top speaker
    • take out bottom speaker
    • When your finished the phone should look like this
Mj H
crwdns2935283:011/08/16crwdne2935283:0
302 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 3,748
