crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0HP G61crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. HP G61-430SB Teardown, HP G61-430SB Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over and remove the screws from the battery. Remove the black panels holding the HDD, ram, and wifi.
  2. HP G61-430SB Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the RAM modules and the HDD as shown in the pictures.
  3. HP G61-430SB Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the screw for the DVD player and remove it. Then remove the DVD player with a thin spudger.
  4. HP G61-430SB Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws to remove the keyboard.
  5. HP G61-430SB Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws that are circled in the picture. These screws hold the case of the laptop.
  6. HP G61-430SB Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the WIFI antenna cables from WIFI card.
    • Then remove the screws of the WIFI card and remove the card.
  7. HP G61-430SB Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop around and gently remove the keyboard with your fingers.
    • Start with the corners of the keyboard.
    • Gently loosen the keyboard with a flat head screwdriver or a thin spudger.
  8. HP G61-430SB Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the keyboard, find the other screws located in the grey panel.
    • Remove the black plastic. Be careful with the white flat cable.
  9. HP G61-430SB Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black flat wire of the LCD screen from the motherboard.
  10. HP G61-430SB Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hinge screws with the screwdriver from the left side to the right side.
    • Under one of the two hinges, there is a hidden screw (case)
  11. HP G61-430SB Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the audio boxes.
    • Remove all the other wires and cables.
    • Then gently separate the screen from the case.
  12. HP G61-430SB Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an iOpener to separate the grey case from the bottom case.
    • Careful: the battery compartment is together with the grey panel.
    • Tip: "slide" the iOpener while opening until you hear clicks. It is easy if you slide.
  13. HP G61-430SB Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motherboard by removing the screws first. Be careful with the cables and the wires.
    • Be careful with the connector of the DC power jack. You can replace the USB drivers on that side as well.
  14. HP G61-430SB Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G61-430SB Teardown: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cooler.
  15. HP G61-430SB Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the Processor, unlock the processor socket with a flat screwdriver.
    • Then gently remove the Processor.
Kevin D
crwdns2935283:005/02/14crwdne2935283:0
7,454 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
Thanks a bunch this helped a whole lot!!!!
Teresa halley - crwdns2934203:0crwdne2934203:0
Thank you very much. Very well explained :)
a.thorne.987 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,366
