crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0HP Compaq 8200 Elitecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. HP Compaq 8200 Elite Teardown, Remove the cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are no screws to remove, simply pull the handle on the cover towards you
    • It is recommended that you do this with the PC flat on the floor
  2. HP Compaq 8200 Elite Teardown, Remove the front cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the front cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the front cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 3 labelled tabs
    • Pull gently upward to release them
  3. HP Compaq 8200 Elite Teardown, Remove the CD-ROM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the CD-ROM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the CD-ROM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the green button
    • Pull the drive backwards until you hear a small click, then raise it out of the caddy.
    “…until you (hear) a small click.”
    Thousand Sunny - crwdns2934203:0crwdne2934203:0
    well that's embarrassing!
    Darohan -
  4. HP Compaq 8200 Elite Teardown, Raise the drive caddy: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 8200 Elite Teardown, Raise the drive caddy: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The drive caddy can be raised to allow access to the 3.5" drive bay below the CD-ROM
    • You don't have to remove the CD-ROM to do this.
    • This makes it easier to access the next 3.5" bay, too.
  5. HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The power supply is hinged, and swings away to reveal a 3.5" bay below.
    • As with the CD-ROM, press the green button to release the drive.
    • Pull back then up to remove.
    • Depending on your configuration, there may not be a drive in this bay.
  6. HP Compaq 8200 Elite Teardown, Access the PCI-E slots: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Access the PCI-E slots: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Access the PCI-E slots: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the bottom-right corner, there is a tab
    • Lifting this up allows screw-free installation of PCI-E cards.
  7. HP Compaq 8200 Elite Teardown, Remove the fan shroud: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the fan shroud: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Remove the fan shroud: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to unclip the cables routed through the shroud before removing it.
    • Only a very minor amount of force is required to remove the shroud.
    • This will allow you to replace the CPU heatsink or fan.
  8. HP Compaq 8200 Elite Teardown, Points of interest: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Points of interest: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 8200 Elite Teardown, Points of interest: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This workstation comes with spare Torx screws.
    • 5 Silver, 5 Black
    • Mine is missing one
    • These are also bitted for a flathead, but I had no luck actually unscrewing with one, so it's not recommended.
    • They are screwed into the chassis under the front cover
    • All screws in this device are Torx TR20. Ensure you have the correct bits before attempting board replacements
Darohan
crwdns2935283:005/07/23crwdne2935283:0
283 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
I want this (pcb)motherboard please show amount
Manoj subhash narwade - crwdns2934203:0crwdne2934203:0
i accadentally blew it up
Cosmo - crwdns2934203:0crwdne2934203:0
I powered off correctly but next day computer failed to power on I tried to change power cable it didn't work no even the sign of light in motherboard. What will be the problem?
JAMES MWALUKO - crwdns2934203:0crwdne2934203:0
I want to install new PSU, but the weird 4 pin connector doesn't look like anything on my thermaltake700 w (overkill, but just in its box here) can anyone help?
David Gagné - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 4,652
