Guide: How to Disassemble Gel Blaster Surge
The Original Gel Blaster: Experience Gel Blaster Surge's unbeatable power, speed, and range. Includes Gel Blaster Gellets designed to maximize blasting performance and precision with Gel Blaster products. Gellets are non-toxic, non-staining, non-irritating and burst on impact, guaranteeing safe and mess-free fun
Remove Easily Detachable Parts
Remove all parts: hopper, barrel, and green thing.
Removing the Hopper
Removing the Hopper Locate the hopper on top of your Gel Blaster Surge. Push back on the mechanism and gently lift the hopper away from the blaster.
Detaching the Barrel
Use the included tool to twist the barrel to allow it to be unlocked and be removed from the blaster.
Taking Off the Green Thing
You kind of just pull on it :3
Note: Keep track of small parts, and consider using a clean workspace to prevent losing any components
Identifying Screws
Refer to the top view picture of your Gel Blaster Surge to locate the 11 screws marked with circles. Using an Philips screwdriver, carefully unscrew each of these 11 screws.
Note: screws are different sizes, Keep track of each one.
Removing the Cover
Once the screws are removed, gently lift, exposing the internal components of your Gel Blaster Surge.
Exploring the Inside
By completing these steps, you have successfully disassembled your Gel Blaster Surge to access most of the internal components.
Refer to the inside diagram to identify the various components and wires. Take note of the wiring layout and connections.
If necessary, disconnect wires according to the diagram. Exercise caution and ensure you remember the connections for reassembly.
Caution: Proceed with the disassembly at your own risk, and be aware of any potential warranty implications.
