crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Geek Bar Pulsecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Geek Bar Pulse Teardown, Loosen clear cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a wood chisel (~1 inch) along the seam to break loose the clear cover. The cover snaps into place but may be lightly glued.
  2. Geek Bar Pulse Teardown, Pull out the internals: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the internals. You will need to push in the on/off switch at bottom of unit to get the insides to slide out.
  3. Geek Bar Pulse Teardown, Detach tank: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach tank. Note location of wiring if you are going to reassemble unit.
  4. Geek Bar Pulse Teardown, Disassemble tank: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Geek Bar Pulse Teardown, Disassemble tank: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Geek Bar Pulse Teardown, Disassemble tank: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off top of tank.
    • Pull heater unit out of steel sleeve.
    • Remove flat wick from heater
    • Observe basket style heater unit. Resistance readings: blk-grn: 1.1 ohms; blk-red: 1.1 ohms; red-grn: 2.2 ohms
  5. Geek Bar Pulse Teardown, Disassemble electronics: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Geek Bar Pulse Teardown, Disassemble electronics: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unsnap the circuit board from the L-shaped plastic holder.
    • View board.
  6. Geek Bar Pulse Teardown, Remove lip piece: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The lip piece can be unsnapped from the inside, pulled out from the top and disassembled as shown.
    I was looking for exact directions on the lip piece filter and rubber because the filter in mine has a film over one side and it’s just like cotton on the other. Does that go up or down inside the gasket or just on top of it when I took it apart mine hit the floor, so I have no idea. Thank you.
    Kelly Colle - crwdns2934203:0crwdne2934203:0
    Sorry, I don't recall how that little oval shaped piece was oriented. It doesn't appear to filter anything & maybe its used to seal the air passage going to the mouthpiece. That film may have been a piece of double sided tape used to hold it in place during assembly ... That is a guess.
    Greg -
Greg
crwdns2935283:008/23/20crwdne2935283:0
260 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Perfect illustration and pics.
Leo Arakel - crwdns2934203:0crwdne2934203:0
love u man, sooo much
Emran Shafaq -
So satisfying. Now it's a perfect secret-stash container too!
PhoenixEd - crwdns2934203:0crwdne2934203:0
I used this to open it and fix an auto-fire/over-fire I was experiencing. I've had it happen before but simply cannot afford to buy another. After opening, I powered it on, hit it & it hit fine. I then switched it off, put the switch cover back on, hit it and back to auto/over-firing again. I removed the switch cover and it was fine, closed it back up without the switch cover and it hits fine, pulls more air in, but I am thinking based off my understanding of vaping herbs that a faster, higher airflow willl create a lower temp & therefore, it shouldn't use up as much fluid per use even tho I have it set to pulse mode. This won't effect the fluid guage as it's predetermined and even if you add fluid while at say 60%, it will not change the level shown or the amount it displays. I'm used to having them display 0% and having several days of full flavor/hits even after this. Thanks for the breakdown, clean, simple, easy to understand. I've opened the Pulse X but never one like this, so thanks.
EROCK611 - crwdns2934203:0crwdne2934203:0
Thank you so much this is going to help me with one of my projects.
Prince Doge - crwdns2934203:0crwdne2934203:0
541125040653
Alee Sg -
I dropped mine the water and now it’s not working so I’m putting the juice part in my other one that’s just hit 0
Cali - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 73
crwdns2936753:07crwdne2936753:0 473
crwdns2936753:030crwdne2936753:0 2,318
crwdns2942667:0crwdne2942667:0 31,286
