crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Garmin Nuvi 200crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Garmin Nuvi 200 Teardown, The parts of the Garmin Nuvi 200: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Top left: back casing
    • Top right: front casing
    • Middle left: speaker. Part ($29) and service at portatronics.com
    • Middle right: motherboard
    • Bottom left: battery. Part ($5.20) at amazon.com
    • Bottom right: LCD screen. Assembly kit ($49) at portatronics.com
  2. Garmin Nuvi 200 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Serial Number Strip is at the base of the device. Remove it to two expose two T5 Torx screws.
    • Using the T5 Torx screwdriver, remove the two T5 Torx screws.
  3. Garmin Nuvi 200 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use care. Do no break apart the strip of orange tape that connects the LCD screen and motherboard (red box in third picture.)
    • Using the plastic opening tool, only at the bottom of the device, separate the back panel from the front panel.
  4. Garmin Nuvi 200 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use care. The glass on top of the screen is delicate.
    • Using the plastic opening tool, push apart the clasps holding the LCD screen in place.
    • Wedge the plastic opening tool between the LCD screen and the metal frame of the device.
  5. Garmin Nuvi 200 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the blue wire from its connector head.
    • Pull the connector head out of the outlet to unplug the speaker.
  6. Garmin Nuvi 200 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #PH00 screwdriver remove the three screws that hold the motherboard in place.
    • Use Screwdriver bit #PH00 in IFixIt's Tool Kit to take out the three screws holding the motherboard in place.
  7. Garmin Nuvi 200 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the strip of orange tape from the white attachment bar on the motherboard.
    • This detaches the motherboard and LCD Screen (see second picture for blue box).
  8. Garmin Nuvi 200 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the strip of orange tape from the LCD screen to detach the LCD screen from the front casing.
  9. Garmin Nuvi 200 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Prop the motherboard up.
    • Hold the red and green wires from the connector head.
    • Pull the connector head out of the outlet to detach the motherboard from the back casing.
  10. Garmin Nuvi 200 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use care. The back casing and battery are glued together. Do not puncture the battery.
    • Push the flat end of the spudger under the battery and separate the battery from the back casing.
  11. Garmin Nuvi 200 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #000 screwdriver remove the two screws holding the speaker in place.
    • Remove the speaker.
Kasey Gray
crwdns2935283:010/28/13crwdne2935283:0
206 crwdns2915208:0crwdne2915208:0
University of Maine, Team 1-11, Diaz Fall 2013 crwdns2935289:0University of Maine, Team 1-11, Diaz Fall 2013crwdne2935289:0
UMAINE-DIAZ-F13S1G11
crwdns2942667:0crwdne2942667:0 13,065
