This is a teardown of the Fitbit Luxe to have a better understanding of the components within. The teardown was part of a design sprint for Memiro, research focused on self tracking and quantified self technology from IIT Institute of Design, Chicago.
Remove packaging to reveal box contents
Use a heat gun, hair dryer, or heating pad to heat the back cover
Wedge a spudger or other opening tool in the seem between the housing and back cover
Pry open the back cover evenly around the edge of the seem until back cover can be removed
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Similar to the previous step, apply heat to the screen
Use a spudger, opening tool, or guitar pick to separate the screen from the housing
Use tweezers to lift the battery from the housing
Use a Torx screwdriver to remove the center screw
This is quite difficult to open the screen. I guess the same happened to the autor - see the picture of the screen glass.
Use tweezer to remove the first bracket
Use tweezers to remove the underlying bracket
Using tweezers, gently remove the battery's connector from the PCB
Lift the battery out of the assembly
Locate the screen's connector on the PCB
Using tweezers, gently remove the connector from the PCB
Use tweezers to lift the haptic module connector from the PCB
Remove the haptic module
Use a Torx screwdriver to remove the two screws on the PCB
Use tweezers to remove the PCB from the housing
Yay you're done! Lay out all the components in true knolling fashion
Look for cracks, and board bents, especially near to the mounting holes (near the haptic feedback unit). My wifes luxe first stopped measuring, later started shutting down itself. When opened it I've found the battery very expanded, which have pressed the board outside and have cracked it, possibly tearing traces in the internal layers.
What chip or module would the firmware be on? I am trying to modify my Fitbit's operating system for more apps, and possibly Google Wear OS.
anybody know where i can buy parts for the fitbit luxe in EU ? looking for the Battery,
Do you have any tips on getting the screen off? I tried using my blow dryer for five minutes but it’s still in the casing
@calvinonofrei I believe it is Ambiq Apollo4 - an ARM Cortex M4 chip with 16 MB of RAM, which I am afraid woult not be a fit for any Wear OS
@rhinounease0o You need very thin metal plate to pry it off, because the gap between the screen and the frame is very tiny. Only hot air wasn't enough im my case. I have soaked it with IPA several times within an hour. this somehow softened the glue allowing me to slide the screen to one of the long sides and get the prying tool on the other long side. Otherwise the tool (0.15mm thick) was no go on either side of the screen. After you get it between the glass and the frame you can use a hair drier to heat it up and gently lift it.
After teardown and replacement of the battery, how do you reseal it?
In my case I haven't even tried to repair it, since it didn't worth it because of the cracked PCB, so I didn't did it. But I would use T8000 glue (it is transparent) to reseal it. Clean everything well with IPA, use gloves nitrilyc(more durable) or rubber and tweezers(clean them too before using) to avoid any oily residues from fingers and dust contaminations. Apply enough glue on the surfaces between the base and display, and between the back cover and the base. I would use small vise with rubber rubber cover on the jawas to keep it tightened (be careful with the pressure to avoid braking the display) for a day while the glue is drying. If there is any glue spew clean it afterwards with a plastic scraper.
