crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Fitbit Charge 5crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Fitbit Charge 5 Teardown, Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Charge 5 Teardown, Device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fitbit Charge 5 device
  2. Fitbit Charge 5 Teardown, Remove back: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove back: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove back: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat the back with a heat gun at 130C to loosen the adhesive.
    • Pry the side opposite the connector area from the strap latch
    • Pry the top and bottom near the connector. There are small plastic pins.
  3. Fitbit Charge 5 Teardown, On the back: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, On the back: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, On the back: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • TI 14WP6JP AFE4500 - Texas Instruments Ultra-Small, Integrated AFE for Bio-Impedance Analysis, Electrical Biosensing and Optical Bio-sensing
    • TI13AD5R8 BQ25156 - Texas Instruments BQ25 series 1S battery charger
    • 121 2624 C72S - Unknown
  4. Fitbit Charge 5 Teardown, Remove Main Board and Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Main Board and Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Main Board and Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry from the sides of the battery to lift out. There is some adhesive/foam between the battery and case
    • You will have to cut the flex cables to the capacitive touch buttons on either side
  5. Fitbit Charge 5 Teardown, Remove Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the battery off and unplug
  6. Fitbit Charge 5 Teardown, Battery Detail: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Charge 5 Teardown, Battery Detail: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 271617 unbranded battery. Marked as 65mAh
    • Mine tested at 24mAh, after a few years of use
  7. Fitbit Charge 5 Teardown, Battery Protection: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Battery Protection: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Battery Protection: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 761EJ1U1 - Mitsumi MC3761 series protection IC with integrated MOS-FET for protection of the rechargeable Lithium-ion or Lithium-polymer battery
    • A temp sensor somewhere
  8. Fitbit Charge 5 Teardown, Remove Can: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Can: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Can: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The can pops off easily with a razor blade starting at the corners
    • Hi Morgan 👋
  9. Fitbit Charge 5 Teardown, Mainboard Detail: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Mainboard Detail: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Mainboard Detail: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 2M AMA4B 212501 HADD - Ambiq Micro, Inc. Apollo4 Blue Lite SoC
    • QUAM V14 - Looks like a custom branded Fitbit chip
    • 12110 U25A - Unknown
    • NXP 100TB2 VC95122 037-080 - Unknown
    • Is this the GPS receiver? (if not, where is it?)
  10. Fitbit Charge 5 Teardown, Remove Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Remove Screen: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat the screen to 130C
    • Push it out from inside
    • As the screen pushes out slightly, it should reveal 3x PH000 screws to undo (I ended up just cutting the metal tabs)
  11. Fitbit Charge 5 Teardown, Screen PCB Detail: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Screen PCB Detail: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Charge 5 Teardown, Screen PCB Detail: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The bluetooth antenna is a spiral around the edge of the flex PCB
  12. Fitbit Charge 5 Teardown, Display Controller: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Charge 5 Teardown, Display Controller: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Raydium AMOLED controller
Knio
crwdns2935283:003/01/25crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 148
crwdns2942667:0crwdne2942667:0 1,565
