crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Fiio M6crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    • This is the full video guide, it begins after i tried to open it from the back. The device should be open from the screen.
  1. Fiio M6 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the device to 110C for 2-3 minutes.
  2. Fiio M6 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the sides of the device carefully (or not if your screen is shattered) . There are 8 plastic tabs holding the screen to the frame, with a little glue in each tab. The top tab is a big tab, so you must begin from the bottom.
  3. Fiio M6 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the LCD ribbon connector in the middle of the frame and you can separate the LCD from the frame. At this point you can put a replacement LCD .
  4. Fiio M6 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Top view of the device opened, the battery is soldered with a little of conformal coating on top of the pads.
  5. Fiio M6 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Back view of the device, The part as identified:
    • ES9018Q2C DAC
    • ICN6211 MIPI LCD controller
    • Exynos 7270, this is a highly integrated chip for wearables, It includes the normal Samsung SOC characteristics, with stacked DRAM & eMMC integrated into the package. That is why the PCB don't have any DRAM or storage chips around.
  6. Fiio M6 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I removed the backplate, but for LCD or battery replacement is not necessary. The battery was glued to the back and there is an antenna on the top .
  7. Fiio M6 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fiio M6 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Battery Detail.
    • Manufactured by SUNDA.
    • 3.7v to 4.2v
    • 1200mAh
    • 624736 pouch form factor
LazarusLong
crwdns2935283:012/08/19crwdne2935283:0
292 crwdns2915208:0crwdne2915208:0
What are the dimensions of the battery?
Barry M. - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 5,549
