crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Fatshark FPV Headset 1000mah Batterycrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut the adhesive label down the seam of the battery case.
    • Do not cut down into the case as puncturing the battery will cause a fire.
    • Separate the two plastic case shells to expose the battery inside.
  2. Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tape holding the battery cells together.
    • Do not stress the tabs on the battery cells or short any of the metallic contacts on the internal circuit board.
  3. Fatshark FPV Headset 1000mah Battery Teardown, Desolder the First Cell: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the First Cell: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the two battery tabs with black and white wires connected to them.
    • Do not short the battery cells or the metallic contacts on the internal PCB.
  4. Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, desolder the battery tabs from the PCB.
    • Second, desolder the main barrel connector wires and balance plug wires from the internal PCB.
  5. Fatshark FPV Headset 1000mah Battery Teardown, That's it!: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, That's it!: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fatshark FPV Headset 1000mah Battery Teardown, That's it!: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Extra photos of components.
David Hoyt
crwdns2935283:004/09/10crwdne2935283:0
4,053 crwdns2915208:0crwdne2915208:0
crwdns2935297:041crwdne2935297:0
Cal Poly, Team 25-89, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-89, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G89
crwdns2935297:061crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,416
