crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Elephone P6000 procrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Elephone P6000 pro Teardown, Battery removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Battery removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Battery removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The 2700mAh battery takes up more than half of the space inside, the dimensions are 76*60*5.0mm.
    • This battery definitely guarantees one day battery life. The battery would last for two days for light users.
  2. Elephone P6000 pro Teardown, Main housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Main housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Main housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The GPS, wifi, Bluetooth integrated antenna is located at top left. On the right side, there is one of the two network antenna, the other network antenna is located at the bottom of the phone. SIM cards slots and TF card slot are under the camera.
  3. Elephone P6000 pro Teardown, Mainboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Mainboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Mainboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing all the screws, we see the mother board which integrates all the chips and cameras. The parts are beautifully organized and we see the a bar code sticker glued on the welded metal cover.
    • The secondary board integrates a USB port, a microphone and a vibration motor which is soldered on the board. It’s fastened by screws.
  4. Elephone P6000 pro Teardown, Mainboard detail: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Mainboard detail: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Mainboard detail: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On top you can see the Dual Micro SIM card (dual standby) and the the camera module.
    • On the bottom of the mainboard you can see the Octa Core MT6753 chip and the Mali T720 GPU.
  5. Elephone P6000 pro Teardown, Board removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Board removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Board removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the FPC (Flexible printed circuit) connection on the mother board, and peel off the protective sticker. There is a piece of FPC connects the secondary board.
    • To take the mother board off, remove the FPC connection with the display. It’s located on the right of the board.
  6. Elephone P6000 pro Teardown, Mainboard removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Mainboard removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Mainboard removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then gently prize up the joint of TP (Touch panel)
    • Disconnect the 2MP front camera.
    • The button volume and power button is glued tightly on the frame, so prize that up with great caution. Then we can take the mother board out.
  7. Elephone P6000 pro Teardown, Camera modules: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The picture shows the OmniVision 13MP primary camera and 2MP front camera.
  8. Elephone P6000 pro Teardown, Front panel assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Front panel assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Elephone P6000 pro Teardown, Front panel assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The LG 5.0” display adopts OGS and IPS technology, which makes the touch panel as thin as 0.79mm and have outstanding viewing angle.
    • The phone uses metal plate behind the screen to enhence the strength and toughness.
    Quick question. How do you remove and install display? Do you need to heat it up for glue to let go?
    Marek Z - crwdns2934203:0crwdne2934203:0
Arie
crwdns2935283:008/01/15crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Can you take a good photo of the top and bottom of the mainboard!
no way - crwdns2934203:0crwdne2934203:0
Please check the (newly added) Mainboard detail step.
Arie -
Ho Arie,
Nice work!
Can you share your experience with changing the microphone in this phone?
Krzyfoto - crwdns2934203:0crwdne2934203:0
Interesting guide!
One of the main bug of the p6000 is the missing standard OTG capability. The OTG works only is the USB device is externally powered. Is it possible for you to check this capability and understand if it's an HW (missing USB power connection) or SW problem? Thank you!
AL - crwdns2934203:0crwdne2934203:0
Is the mobile data antenna in the same place as in the p6000(no pro)? Where's it? I pretend to crash the antenna in order to buy a new mobile phone :pp Thanks!
abelcarus - crwdns2934203:0crwdne2934203:0
You can power the USB device with such or a similar a OTG cable:
http://mobilamb.eu/accessories/usb-cable...
Albert Einstein - crwdns2934203:0crwdne2934203:0
Can you please tell me if the blue led of the home button is part of the secondary board or is it located on the LCD ?
Milke - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 11,249
