crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon)crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown, EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown, EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the cover off the humidifier
  2. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the dial and pull away from the device.
  3. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the water tank off the base
  4. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the valve at the bottom of the tank.
    • Twist the valve counterclockwise to remove it.
  5. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the base upside-down
    • Connect the 4 mm nut driver to the 4 mm aluminum driver. Then, connect the PH1 head to the 4 mm nut driver.
    • Insert the driver into each of the 4 holes and twist counter clockwise to remove the screws.
    • Flip the base upright and pull off the top.
  6. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect a PH1 head to the 4 mm aluminum driver
    • Unscrew the circled screws of both the circuit board and heating plate(metal plate)
    • Gently remove the circuit board
  7. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull out the fan (located in the red rectangle)
    • We recommend removing the circuit board before attempting to completely remove the fan.
    • Unplug the pin, connected to the circuit board, to remove the fan.
    • Note: Remove the pin cautiously, the edges may hurt your fingers.
  8. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The LED is connected to a pin that is connected to the circuit board.
    • Upon close inspection, you can see that the LED's two ends are bent (red circle of the second image) to prevent it from slipping off of the pin.
    • Use blunt tweezers to bend and straighten the two ends.
    • Once the two ends are straight, gently pull the LED out of the pin.
  9. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws (located in the red circles) off of the heating plate with a 4 mm aluminum driver with a PH1 head.
    • Once the screws are removed, gently pull off the metal plate.
  10. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All the inner components of the humidifier.
Paul
crwdns2935283:002/15/17crwdne2935283:0
127 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-5, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 8-5, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S8G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 2,347
