On This Segment of Hp 625 Teardown, You Will Learn How To Disassemble and Build More Skills Towards Your Endevour.
Unscrewing Hp 625 Service Door (4 Screws).
Removing of Hp 625 HDD, (Gently Slide).
Unscrewing of Hp 625 DVD Drive, (1 Screw)
Removing of Hp 625 DVD Drive, (Carefully Slid).
Removing of Hp 625 DDR3 RAM, (Together With Two Hands Expand The Clips a little).
Hp 625 DDR3 RAM Removed, ( Be sure not to Touch The Gold Plated Pinouts).
Unscrewing of Hp 625 Keyboard, (6 Screws Noted By Keyboard icon).
Removing of Hp 625 Keyboard Flex Cable, (Gently Release The Locking Mechanism).
Disconnecting of Hp 625 Power Flex Cable From Connector, ( Fairly Unlock The Locking Mechanism).
Hp 625 Power Flex Cable Disconnected.
Unlocking of Hp 625 Palm Rest, Through The HDD Bay.
Disconnecting Touch Pad Flex Cable and Removing of Hp 625 Palm Rest.
Unscrewing of Hp 625 System Casein, (16 or More Additional Screws Verify Very Well For Additional Screws Needed To Be Unscrewed Before Removing The Casein).
Removing of Hp 625 Front Casein, (Firmly Pry the Casein, Starting from Any Edge).
Unscrewing of Hp 625 Thermal Fan, (1 Screw).
Unscrewing of Hp 625 Thermal Conductive Heatsink, (6 Screws).
Hp 625 Thermal Conductive Heatsink Removed.
Unlocking of Hp 625 AMD Processor From Socket, (Anti-Clockwise).
Disconnecting of Hp 625 Wi-Fi Cables From Wireless Card.
Disconnecting of Hp 625 HDD Card From Motherboard.
Disconnecting All Cables of Hp 625 Connected To Motherboard.
Complete Disassembled Parts and Components of Hp 625.
'Reparatur ist edel
Excellent guide, and more importantly: Outstanding outfit!
Is there an easier way to replace the rtc battery than taking the whole thing apart - ANYONE???
crwdns2935229:09crwdne2935229:0
You mentioned there are 6 keyboard screws. I can find only five. Can you be more specific (detailed) in where these screws exactly are. Thanks
Hello Simakos71, follow this YouTube link: https://youtu.be/91JQ596T0og to know strategic places the screws are located.
samuel -
Whats a good way to follow i really want to be repairing but i need your advice on how to start thanks
engiengimib@gmail.com
